Center to origin
All  1-5  6-12
2409.6 In reply to 2409.2
Thanks very much for making this & Thanks to PaQ for requesting it.
FWIW I'm using F4 as my keyboard shortcut so it'll match up for use when I'm using Rhino.
regards Colin
2409.7 In reply to 2409.5
Hi PaQ,
> Just a other question, is it possible that the 'center at origin'
> works with the cplane too ? so the selection is center to the
> cplane origin when you're using a cplane, or to the world
> when cplane is off.
Yup, it's only a tiny adjustment to make that work.
I've updated the attachment to that previous message
(http://moi3d.com/forum/index.php?webtag=MOI&msg=2409.2)
to work like that now, so just copy that new version over top of the previous one.
2409.8 In reply to 2409.7
haaaaa really cool, thanks for taking a bit from your time to this script Michael !
2409.9
I am trying to run this script with a shortcut and the selected object disappears.
When I run it via the script menu at the bottom, the object is centered as expected. Any ideas what could be wrong?
edit: I remember it was working fine at some point- no idea what changed
EDITED: 27 Feb 2022 by NAMELESS
2409.10 In reply to 2409.9
Is the object too small to see? , or is it located outside of the viewing area?
2409.11 In reply to 2409.9
Hi nameless,
I can't repeat the problem over here, does it happen just with a particular object? If so can you please post a .3dm model file with the object in it?
2409.12
Thank you for looking into this. I found what the problem was- Numlock was not pressed when I tried it, so it somehow registered the period as a coordinate or size input.
Trying again with Numlock on and the script works, object is centered just fine.
Apologies for wasting any reader's time with this. :\
Show messages: All  1-5  6-12
