exporting to other 3d softs
 1-20  21-23
240.1
Hi everybody!
i very recently discovered MOI and have a lot of fun playing with it, but my aim is to create 3D objetcs that could be part of 3d scenes, and would not stand "alone". Otherwise, it would be uselessfor me...
So I would be more than happy if I could create files like .dwg or .3ds or any that would be acceptable by softs like Sketchup, Bryce, Mojo. Is there a trick, like exporting to an intermediary soft (Rhino or others???) that would itself export in the extensions I need???
Please, if you can be of any help, you would make me so glad... (and you want me to be glad, don't you?)
tks a lot
Eric
240.2 In reply to 240.1
You have yet the format "Obj" export that you can reload in any 3D softs :)
Menu FIle /Export OBJ and you can make some choices that you wish:)
Clic yours objects on the canvas, choice the nature of export
3dm, iges, Stl, or "OBJ" :)
Enter a name
And you will appear your object in it futur aspect in polygons :)
You can enable some caracteristics of export nb of poly, quad triangles etc...
Seems it's the better system Nurbs ---> polys at this day ! (all progs confused)
Michael has made a crazzy work !
EDITED: 5 Dec 2006 by PILOU
240.3 In reply to 240.1
I have already asked Michael about exporting to Autodesk formats... It will be done but we'll have to wait, it's not a top priority... For now, you can use obj format and problably a low-cost or free transformation obj to dxf or obj to dwg or obj to 3ds... search with google. If you have any other 3d app like viz or max then you can use obj immediately.
240.4 In reply to 240.2
Well thank you!
But when i click "export" it does not show any polys object (is there any pref to set, to see the polys???)
thanks
240.5 In reply to 240.4
that'it : you see the polys only if you name the file a different name from the one you export from (am I clear???)
Thank you, JTB, i'll browse to find a file "transformer", unless you can advise one reliable prog you know.
tks for your attention
and good works to all
240.6 In reply to 240.5
Seems you have not very well folow my previous post :):):)
240.7 In reply to 240.6
si,si my dear, i follow ton previous post, but in the same time I am au boulot, so it is a little diffikult!
en fait, it is the fichiers 3ds that i am really interested in, wich is not an exportable file format...from MOI
tks for your aide, Frenchy Pilou!!
240.8 In reply to 240.7
An easy free solution is Blender http://www.blender.org/
Import the Obj from MoI, export in 3Ds toward Max :)
Use Blender is an another Story, the Ui is some special! :D
Or more easy import the OBJ from MAx :D
240.9
Another free program is Meshlab
http://meshlab.sourceforge.net/
I have tried to stay away from .3ds because it has several limitations - .3ds files are limited to triangles only (instead of allowing many-sided polygons), and they have a size limit of 65535 points/polygons for a single mesh. And in addition they don't have the ability to contain a type of smoothing information called "vertex normals". The .obj format doesn't have these limitations.
Most software that can read polygon information can handle .obj files, but I guess that there are unfortunately a few that don't - I guess Sketchup is one of these. Are there others?
I guess that I can add .3ds format if it is really necessary. It is actually a lot less work to add .3ds than DXF/DWG.
240.11 In reply to 240.5
This should be fixed in the most recent beta (version Dec-1) - with this version, it should change the file extension when you change the "Save as type" dropdown.
240.12 In reply to 240.10
By the way, which types of data may be included in the exported .obj file by MoI.
- group name (g),
- object name (o),
- smoothing group (s),
- vertex data (v),
- texture vertices (vt),
- vertex normal (vn),
- face(f)
something else?
Petr
240.13 In reply to 240.12
Export to Google Sketchup works fine with the gobetween Blender Obj -->dxf :)
(3DS don't want work in Google Sketchup ??? with the Canon file of Steph :(
Here my try with only less triangles (other Ngones or Quads + trianles don't well works for Google Sketchup)
Ps During the export in MoI does it possible to see somewhere Numbers of Polygones?
Ok I have seen it! It's Up page right corner in MoI ! :)
240.14 In reply to 240.12
> something else?
Nope, that's all of it for now. Eventually material support will be added once MoI actually has render materials.
240.15 In reply to 240.13
Yup, but it sure would be nice to bring n-gons into Sketchup since Sketchup does support multi-sided polygons.
It's really unfortunate that Sketchup does not read .obj files right now.
Yup, that's brand new for the last beta.
240.16 In reply to 240.15
Hi Michael
I have found a Ruby script for import OBJ file format in Sketchup :)
http://www.crai.archi.fr/RubyLibraryDepot/Ruby/RUBY_Library_Depot.htm
Not yet tested but... suspense If it's works that's a true gem :):)
You must have this progressBar.rb
and the principal script : Objloader.rb
All is free and must put into the folder Plugins of GoogleSketchup http://sketchup.google.com/
I will test that :)
oups don't more exist :(
240.17 In reply to 240.16
Too bad! :(
240.18 In reply to 240.17
No Refound it here :)
http://forum.sketchup.com/showthread.php?t=72133
and you can load the file objloader.rb (slide the page)
he said "Still doesn't handle negative face indices, i am working on it"
hum hum :)
Progress bar can be found here http://www.smustard.com/script/ProgressBar and press download up page right corner
Suspense again !
240.19 In reply to 240.18
Cool!
That's ok for MoI - MoI never writes negative face indices (it is an optional way to structure the OBJ file).
240.20 In reply to 240.18
But looking at that code, it looks a little bit too basic - it seems to only gather just 3 points per face, so I think it is assuming that there are only triangles in the .obj file... :(
Show messages:  1-20  21-23
