3D Complementary Software for MoI : texture and organic shape (Beginners)
All  1-3  4-6
2385.4 In reply to 2385.3
> Are there 2 renderers? One for the nurbs, one for the OBJ?
> if not that mean they transform nurbs in polygons?
You will probably need to ask that question to their tech support to be sure, but most likely they will transform NURBS into polygons when they do the import. That is by far the most common method.
2385.5
Hi
I hope you don't mind if I give links (sometime people give link for better positionning in google, or advertise their product). But I only do it to make it simplier for anybody to go on their website.
>I'd heard something about 3D Paint Brush recently, but I didn't know that it could import .3DM NURBS
>models directly, that should make it fit well to use in combination with MoI.
I guess, file is converted to polyons, since 3d paint brush can't export 3DM file.
Nevertheless, "import 3dm", is usefull for begginer. They don't have to think about file format.
Their left tab is quite similar to MoI interface, so it's quite easy to switch between the two softwares.
They say you can copy and paste 3D object directly without saving from others sofware with their 3Dsnip tool but it don't work with moi3D (I've tried sketh up7 it's ok). I suppose it's only for polygonal object. But in fact It's not important since you should save 3DM file before adding texture (if you want to modifie your 3DM file later).
2385.6 In reply to 2385.5
Hi pp - re copy/paste - if you are in contact with their tech support you might forward them this link from a post in another forum:
http://www.spaceclaiming.com/xn/detail/2118765:Comment:10601
That gives some information on how to make a Copy/Paste function that will work between MoI and also Rhino. Basically it is just a 3DM file that is stored in the clipboard, so it is probably pretty easy to add support for this if you already have support for 3DM files.
EDIT: now that I think about it, they probably like to do Copy/Paste in both directions, and the backwards direction (from Paint into MoI) would not work in this case since they convert to polygons like you were mentioning. So this would be for a kind of one-way paste from MoI into their app and not backwards.
Show messages: All  1-3  4-6
