Autodesk InventorFusion goes Public
All  1-5  6-8
2378.6
Thanks Michael,
I think i'll stick with moi for now as i already use archicad and c4d for modelling as it is! I just admire the apparent intellegence and flexibility of the direct modelling approach. Would be great to see some more history based model update features in moi, like adjusting fillets at a later date etc. Currently is it right that not all sweep opperations update automatically? I have experimented with paths that are besier based which do update the sweep object as the points are moved but if the path consists of straight lines the sweep object wont update when the paths points are moved. Will this sort of behaviour be fixed when you come to look at auto mitering of sweep shapes?
Rob
2378.7 In reply to 2378.6
Hi Rob,
> automatically?
One of the limitations currently is that if your operation produces multiple separate output objects from one input object, that history updates won't work in that situation.
When you have a segmented path with sharp corners in it (like a polyline), then it will produce multiple separate output objects for each segment with the current sweeper.
Yeah actually I think it should because the mitered result will be one solid (which will count as one output object even though it is made up of multiple joined surfaces) so it should then work with history updates in the current system.
2378.8
Sweet, thanks as always, moi v2 sounds like it's going to be awesome!
Show messages: All  1-5  6-8
