Bonzai 3D beata released
 1-19  20-24
2377.20 In reply to 2377.19
> When you have a multiple boolean with complex volumes
> that can't be "real time" ;)
No - not for the fully general purpose booleans, particularly when things get complex it involves a large number of calculations. A large number of calculations does not usually combine very well with "real time".
But like I was mentioning for this new possibility of doing an extrude with boolean combined, it may be possible for me to do a specialized boolean that may work faster than the regular general purpose booleans. It is probably worth a try anyway when I get a chance to work on it.
> Move all cylinders with the boolean function over the
> sphere seems problematic :)
This new function that I am talking about would not do that job - it would be for extruding a set of curves from a plane on an object, something like this:
However, the primary purpose of this is not to do a real-time boolean, it is to avoid the need to do the boolean as an additional operation to make for fewer steps in the workflow...
2377.21
Well I was hoping for realtime booleans so this fits the bill just as good!
Hopefully you'll be able to get it going, Michael.
-Will
2377.22 In reply to 2377.20
< However, the primary purpose of this is not to do a real-time boolean, it is to avoid the need to do the boolean as an additional operation to make for fewer steps in the workflow...
OK :)
2377.23 In reply to 2377.20
A patch has been released which seems to have stablized the software. So it can be actually tested out now (for those interested in it).
EDITED: 15 May 2013 by PILOU
Show messages:  1-19  20-24
