license key (box ) problem
All  1-3  4-8
2369.4 In reply to 2369.1
Hi snookster - I got your e-mail and sent you a reply an hour or so before, if you did not receive it you might check your junk or spam mail folder, maybe it was routed to there.
I will also post it here as well just in case:
Hi snooky snooky - this happens due to a bug in IE8 beta2.
The bug in the IE8 beta causes MoI to not be able to display
OK or Cancel buttons as it normally would.
Currently to use MoI version 1.0 you will need to uninstall
the beta version of IE8 and go back to the regular release
version of IE7, I think there is an entry for this in the
"Add/Remove programs" area under something like "Windows
Internet Explorer 8".
I'm waiting to see if they fix the bug in their
final release of IE8, if they don't then I will put out a
patch to make MoI v1 work with it.
The current v2 beta does have some changes that avoid this
problem, so at the moment if you can't uninstall the IE8
beta from your system you could instead use the MoI v2 beta
which you can download from here: http://moi3d.com/beta.htm
2369.5 In reply to 2369.3
Hi jonah,
> Do you think i may hit that same problem again?
It's kind of hard to say - it sounds like your previous problem may have been some kind of bad installation of some system components.
I wouldn't think that installing Visual Studio should have any bad effect on MoI but if a system component does not get installed correctly all kinds of weird things can happen certainly...
If you run IE right now, what is the version number that is reported under Help/About? Maybe you got back to an IE7 install which then made MoI work.
It should normally be possible to uninstall the IE8 beta, so I'm not sure what happened in your case previously where you said you couldn't uninstall it? Note that its entry in the Add/Remove programs list is a bit different than what you might expect - instead of being under something like "Internet Explorer", look for it under "Windows Internet Explorer".
Also, probably a good idea to avoid installing beta OS components on your production system if possible! A beta of an individual specific program is certainly fine normally, but beta OS components have a lot more potential to mess things up.
2369.6
has this been fixed?
i tried re-installing MOI this afternoon and got into the same problem.
i'm running IE8 version 8.0.6001.18702
vince
2369.7 In reply to 2369.6
Hi Vince, the problem where the OK and Cancel buttons do not work properly when IE8 is installed is fixed in the 1.1 update.
You can download the update installer here:
http://moi3d.com/1.0/update/moi_v1_1_update.exe
If you run that updater, it will patch your 1.0 install to be version 1.1 that should now work properly with IE8.
Please let me know if you have any problems after doing the update.
2369.8 In reply to 2369.7
Ooops!
i should've looked for an update first before asking.
everything works fine, tnx Michael! :)
Show messages: All  1-3  4-8
