Hi snookster - I got your e-mail and sent you a reply an hour or so before, if you did not receive it you might check your junk or spam mail folder, maybe it was routed to there.
I will also post it here as well just in case:
Hi snooky snooky - this happens due to a bug in IE8 beta2.
The bug in the IE8 beta causes MoI to not be able to display
OK or Cancel buttons as it normally would.
Currently to use MoI version 1.0 you will need to uninstall
the beta version of IE8 and go back to the regular release
version of IE7, I think there is an entry for this in the
"Add/Remove programs" area under something like "Windows
Internet Explorer 8".
I'm waiting to see if they fix the bug in their
final release of IE8, if they don't then I will put out a
patch to make MoI v1 work with it.
The current v2 beta does have some changes that avoid this
problem, so at the moment if you can't uninstall the IE8
beta from your system you could instead use the MoI v2 beta
which you can download from here:
http://moi3d.com/beta.htm
