shell
All  1-12  13-14
2366.13 In reply to 2366.12
I ended up using merge to cut the door and windows out of the solid, after which I had to delete a couple of faces. I presume there is a better method? I tried several boolean operations, but the above was the only one which seemed to work.
2366.14 In reply to 2366.13
The model you posted was not solid. So there was some problem during your building,.. either the model was not solid before the merge or the curves you used (with the problems I highlighted) have caused the problem.
Put a sketch together of what you are trying to build and post this,.. we can go through the process of construction. At the moment we are jumping from problem to problem. lets start from base and go from there, if that is OK with you?
regards,
Show messages: All  1-12  13-14
