Ray-fish
 1-11  12-31  32-33
2352.12 In reply to 2352.11
Yannada - thanks for the link, I will sure check it out. Was inspired by Rinus Roelofs - http://www.rinusroelofs.nl/pr-c-holes/pr-c-holes-00.html
Manz - another possibility that I would've never thought of. I'll give it a try.
/Lars
2352.13 In reply to 2352.12
This was a nice experiment, I'll go on to try out the different suggestions you've given me, just a quick sketch of another one, not so smooth yet...
/Lars
2352.14 In reply to 2352.11
@Manz: Damned! That is "the solution" the more easy ! Bravo ! :D
I am so dumb to not have though to that :)
Very cool links!
EDITED: 24 Jan 2009 by PILOU
2352.15 In reply to 2352.14
I decided to build that surface from a network (egg carton)
Create the surface.
boolean the holes, then copy and postion.
Add shell
There are some nice shapes shown on the link, I will have to play more.
EDITED: 3 Aug 2009 by MANZ
2352.16 In reply to 2352.15
Really nice, but now you have to relate how you go about in creating an egg carton surface.
/Lars
2352.17 In reply to 2352.16
Create a curve, here I have used the "through points" curve to create a wavy curve using snaps.
Use that curve and create the square boundary, then select all 4 curve and select "network".
I have attached the curves which may better explain.
2352.18 In reply to 2352.17
Maybe this link can interest you ;)
http://www.materialsystems.org/?page_id=161
Some amazing things anywhere in this site!
2352.19 In reply to 2352.18
I will have to make time to take a longer look at those images,.. some strange shapes indeed.
Thanks for the link.
2352.20 In reply to 2352.13
Hi Lars,
I had a play with building the 3 surfaces interlocking. It did not come out exactly as planned, but was OK.
2352.21 In reply to 2352.20
Hi Manz,
nice one. It's a nice interwoven structure and I plan to experiment more with it too.
Tell me, the red color... remember seeing a screenshot from Michael some time ago where he showed an idea for that, but is it actually implemented in the latest beta? How does it work?
I'm trying to learn a bit in the parametric plugin for Rhino called Grasshopper. So after all the tips and ideas from you, Pilou and Yannada I figured I had enough understanding of this surface to try it out in Grasshopper. So now I can change at least a few parameters with sliders in Grasshopper.
/Lars
2352.22 In reply to 2352.21
I have not seen anything in the latest beta for changing colors of an object, I would think that will be included when the Groups are added.
On the screengrab, I just have (on that setup) the surface selected color set to red in the MoI ini file. The entry I changed was "SurfaceSelectedColor=" and made it 255.0.0
2352.23 In reply to 2352.21
hello all :)
very interesting Lars ;)
http://forum.jotero.com/viewtopic.php?t=25&start=457
ciao
torolf
2352.24 In reply to 2352.23
cool site about Erwin Hauer !
EDITED: 26 Jan 2009 by PILOU
2352.25 In reply to 2352.23
Wow! Very beautiful.
I've only just started to imagine those intersections on a 3d-surface, and thought I would start easy with a cylinder or something...
Now I know what to head for! Excellent.
/Lars
2352.26 In reply to 2352.25
Hi Lars,
With the current MoI toolset you will struggle and have to make a lot of construction for the interweaving surfaces around a cylinder (or sphere etc).
For solid work I now usually use VC pro which gives more advanced filleting/shelling etc. The 2 interweaving surfaces I made (image posted earlier in the thread) I imported them into VC pro and bent them around a circle.
2352.27 In reply to 2352.26
Hi Manz, and thank you for the warning..
Actually this was all meant like an exercise in Rhino - Grasshopper. I've made a definition that lets me control some parameters.
http://screencast.com/t/fiarUgsOF
The idea is to go on and "map" this geometry to a surface in Grasshopper. But I haven't got round to that yet. On Torolf's site he mentions Paracloud, and I thought I'd try it out in Paracloud Gem too, basically you open up this interwoven figure and some interesting surface and then let Gem map the figure all over the surface. But I'm still at the part where I'm trying out different variations on this theme.
/Lars
2352.28
The potential of GH is really awesome. I've used it to build a few parametric objects that went to production already. Only problem were fillets had to be added post-GH... How did you define the initial trimmed surface? Did you share this ghx file on the GH discussion forum? I'm curious to see how you did it...
thanks,
jonah
seems very quiet forme :)
With the same concept the primitive form can be with numerous branches and forms
2352.30 In reply to 2352.28
Hi Jonah,
the MoI/Grasshopper combo is really great. During this last months a feel I've learned a lot about modelling from both.
Used the technique that Manz showed together with the info in the pdf that Yannada provided. Actually I cut Manz curves in half, so it's one curve, mirrored and rotated. And then used them for a one rail sweep. Then it's just a matter of mirroring and rotating. I do plan to show it to the GH forum once I've come a little further.
Would be very interesting to know more about your GH projects, I'll send you a pm in the GH forum tomorrow.
/Lars
2352.31 In reply to 2352.30
Thanks Lars! That's very nice of you. Actually I'd posted some interesting utilities which were made in early versions of GH (.wrm files). They should still work in the current GH versions. But if you open them, you will see I had to use many workarounds for nodes which were not available then. Now it's much easier! Anyway, my favorite utilities I made so far were:
**Bounding Box Analyzer - you can input as many Rhino objects as you like, then use sliders to flip among the inputs and see the measurements displayed on screen. Options for box display as bounding box, ghosted, or none... Now it's somewhat obsolete because of the BoxEdit plugin. But i still like the function of my GH version... :)
**Isocurve length analyzer - use sliders to measure isocurve length along any face of a polysurface. You could either use the surface isoparms, or slide to any point in between. Also you could adjust the thickness of curve display (by adjusting the radius of piped curve)...
**Live Sectioning - gives real time cross section display of any polysurface, with slider controls to move the clipping plane and also spin the plane along any axis. Also can flip direction, and can display either intersection curve, intersection plane, or cutaway solids...
**Snapping slider - creates an adjustable "snapping point" for a slider, and has adjustment for the snap tolerance...
I think i posted all those to the GH forum, but since then I'd made better versions which were not posted. I don't want to post them publicly because they're not well tested under different situations. But let me know if you want to play with them, I could PM them to you... I would like to rebuild the definitions for isocurve and for sectioning when I have time, because now they can be much improved with the scripting nodes involved. But I think maybe it's better just to learn programming and make proper tools as they would be much more efficient anyway!
I am jbarnett on the GH group... Thanks!
jonah
Show messages:  1-11  12-31  32-33
