New Dec-1 beta available now
 1-6  7-24
234.7 In reply to 234.6
< but then I decided to just go ahead and use the whole word
So I will make the same in french :)
Contract words will be always possible after if the "Moving barr" is so irritating :)
Ps In what file is the new Export Objet menu OBJ ? I have a little miss :)
Ok I find it ! mesh dialog :)
Ok beta french version of the 1er december Beta Moi is available :)
http://moi3d.com/forum/index.php?webtag=MOI&msg=217.1
I have modify from the previous
In Ui
commandbar
commandbar right
meshdialog (and erase previous meshobj)
and the rest
In commands
seems commands not change ?
So from your list that I have not seen by crossing post, I have some modifications to make :)
Done :)
EDITED: 2 Dec 2006 by PILOU
234.9 In reply to 234.8
Very cool Pilou! Merci beaucoup!
> In commands
The UI inside of commands didn't change, but I forgot to mention that 2 script files in the commands did change, so you may want to update these 2 files in your French .zip : arctangent.js, circletangent.js
This change was an update to arc and circle tangent so it could function better in the 3D view - now it will track points on the plane of the 2 curves that are picked instead of always tracking on the view's construction plane. So for instance getting the tangent circle off of any two edges of a cube in the 3D view is now easier, before it was hard to do that with circle tangent or arc tangent.
234.10 In reply to 234.9
cool updates!!... the obj options are realy cool :)
now all we need is a layer system
234.11
ok i updated the german translation.I hope you will introduce a central string resource file soon. ;)
MfG
sk2k
http://poi.sturmwelt.de
234.12 In reply to 234.11
THX !!!! Great work
234.13 In reply to 234.9
Aaaah! :)
Do you mean that all "xxx.js" must be change or just the 2 "tangents"?
In the previous version, the "xxx.js" has some texts to translate?
Because I have made nothing in these sort of files only in the htm:D
I am anxious of your answer :)
234.14 In reply to 234.11
<I hope you will introduce a central string resource file soon.
yes but it's not a very hard work ?
234.15 In reply to 234.14
For him or for us? ;)
It's better for tracking text changes from version to version so the translation process will be easier for us.
Btw. there is no need to translate the .js files as the contain no translateable resources.
MfG
sk2k
234.16 In reply to 234.15
yes if prog was conceived for futur translation :)
For the JS file "arctangent" this follow is only code and no text?
>ui.beginUIUpdate();
> ui.hideUI( 'ThirdPrompt' );
> ui.hideUI( 'RadiusOptions' );
> ui.showUI( 'FourthPrompt' );
> ui.endUIUpdate();
234.17 In reply to 234.16
Yep, that's only code.
MfG
sk2k
234.18 In reply to 234.16
> For the JS file "arctangent" this follow is only code and no text? <...>
Yes - I just mentioned this because I thought you made a copy of all the files in the \commands directory, including these .js files. So to make your .zip file up to date you would need to update these files in it.
234.19 In reply to 234.14
I'm working on a string resource file today. So once that is ready all the changes for translation will all be concentrated in a single file.
234.20 In reply to 234.19
That sounds good. :)
MfG
sk2k
234.21 In reply to 234.18
< you made a copy of all the files
Thx but...
... this time, i Just copy the files htm :) More speedy and "little size" for the users !
So no problem with new files and nothing to add :) (except the news of course)
And bravo if you can make a special list for translation! :)
So everybody can make his own translation!
MoI in Esperanto or Klingon must be terrific :)
EDITED: 3 Dec 2006 by PILOU
234.22
I am unable to find the download for the Dec beta. Has it been taken down?
Thanks for the updates Michael!
234.23 In reply to 234.22
It's there. I just got it.
MoI Home/Downloads , it's the only one listed, along with the french docs below it.
234.24 In reply to 234.22
Nope, it hasn't been taken down, you should be able to grab it from here: http://moi3d.com/download.htm
Maybe hit reload on your browser?
Show messages:  1-6  7-24
