> Have you a list of the Commands & Ui who have changed or even added?
> More easy for translate :)
> Else I will make without :)
One way you can get a full view of changes is to download windiff.exe from here:
http://www.microsoft.com/downloads/details.aspx?FamilyID=49ae8576-9bb9-4126-9761-ba8011fabf38&displayLang=en
Then run it to compare the two directories, you will then get a line by line comparison of changes. Here's the list that I got from doing this:
\ui changes:
CommandBar.htm: changes to Top/Front/Right tab buttons, there are 3 areas to edit on each of these buttons, the inner text ( like <...>Top</...> ), then also the text="" and reversetext="" attributes as well.
CommandBarRight.htm: update icon names from ExpandToFullScreen.png = Expand.png and ContractFromFullScreen.png = Contract.png
MeshDialog.htm - some new UI for controlling meshing options.
Deleted files: ContractFromFullScreen.png, ExpandToFullScreen.png, FrontBackTabMenu.htm, meshdialogobj.htm (there is now just one mesh dialog), RightLeftTabMenu.htm, TopBottomTabMenu.htm and ViewTab.js
New files: Contract.png, Expand.png, MeshInfo.htm (this displays the point and polygon count in the command options area in the upper-right of the main window while the mesh dialog is being used).
\commands changes:
No UI changes to \commands files for this release.
