New Dec-1 beta available now
 1-14  15-24
234.15 In reply to 234.14
> <I hope you will introduce a central string resource file soon.
> yes but it's not a very hard work ?
For him or for us? ;)
It's better for tracking text changes from version to version so the translation process will be easier for us.
Btw. there is no need to translate the .js files as the contain no translateable resources.
MfG
sk2k
234.16 In reply to 234.15
yes if prog was conceived for futur translation :)
For the JS file "arctangent" this follow is only code and no text?
>ui.beginUIUpdate();
> ui.hideUI( 'ThirdPrompt' );
> ui.hideUI( 'RadiusOptions' );
> ui.showUI( 'FourthPrompt' );
> ui.endUIUpdate();
234.17 In reply to 234.16
Yep, that's only code.
MfG
sk2k
234.18 In reply to 234.16
> For the JS file "arctangent" this follow is only code and no text? <...>
Yes - I just mentioned this because I thought you made a copy of all the files in the \commands directory, including these .js files. So to make your .zip file up to date you would need to update these files in it.
234.19 In reply to 234.14
I'm working on a string resource file today. So once that is ready all the changes for translation will all be concentrated in a single file.
234.20 In reply to 234.19
That sounds good. :)
MfG
sk2k
234.21 In reply to 234.18
< you made a copy of all the files
Thx but...
... this time, i Just copy the files htm :) More speedy and "little size" for the users !
So no problem with new files and nothing to add :) (except the news of course)
And bravo if you can make a special list for translation! :)
So everybody can make his own translation!
MoI in Esperanto or Klingon must be terrific :)
EDITED: 3 Dec 2006 by PILOU
234.22
I am unable to find the download for the Dec beta. Has it been taken down?
Thanks for the updates Michael!
234.23 In reply to 234.22
It's there. I just got it.
MoI Home/Downloads , it's the only one listed, along with the french docs below it.
234.24 In reply to 234.22
Nope, it hasn't been taken down, you should be able to grab it from here: http://moi3d.com/download.htm
Maybe hit reload on your browser?
Show messages:  1-14  15-24
