Filleting
All  1-6  7-9
232.7 In reply to 232.5
Hi Petr, yes this is a problem.
The way I have been planning to solve it is with:
4) Perform the fillet calculation in the background and automatically cancel it and start a new calculation if a new radius has been entered.
Which has the only problem that it is quite difficult to achieve... :) However, I have been planning on this since there really needs to be a way to cancel long operations in general anyway even separate from this particular issue.
I've tried really hard not to have things like "preview" buttons, I really prefer to just do the preview automatically.
232.8 In reply to 232.6
> For the critical filets, is not more tricky to draw by "hand" the
> profil and sweep it along curves wished? :)
Hi Pilou, it is certainly possible to generate some fillets in this way, but you'll also have quite a bit of work to do to fill in corners and handle intersections between the different fillets.
But that's actually one of the nice things about a "hybrid" modeling system like MoI (where you can work on solids or also on individual surfaces and join them together later) - that you can get in there and construct a fillet manually in some cases where an automatic solver isn't able to handle it.
It is not exactly easy to do though.
232.9 In reply to 232.8
Sure and perfection is not for this world :D
EDITED: 4 Dec 2006 by PILOU
Show messages: All  1-6  7-9
