Mesh export problems
2318.1
I've been experimenting with exporting meshes into modo today - trying to find the smallest poly numbers and understand the settings better.
However, I kept coming up with this type of error in the mesh.
Sometimes I can get it to go away.
Is this something that can be fixed - and if so, is it on your list for V2?
Tony
2318.2 In reply to 2318.1
Hi Tony -
It's not quite an "error" exactly - by which I mean the mesh is valid and closed, without flipped polygons, etc... Basically that happens if some of those polygons got additional points in their boundaries so that they formed n-gons rather than simple quads.
But yes I want to tune it up to avoid this happening when possible, which should be the case for the examples you've got here.
I did some work that was new in the Nov-21 beta to help avoid this for surfaces of revolution (for different cases than you have here), and for the next beta it looks like some other general tune-ups that I've done have already solved your example here. So it looks like this should be fixed with the next beta.
2318.3 In reply to 2318.2
That's great - thanks Michael. I'm look forward to the next beta.
Tony
2318.4 In reply to 2318.3
I've been overhauling the mesher quite a bit for this next release. These changes hve been primarily to increase speed of the export meshing, but there are also a few other bug fixes as well.
I'm still working on a couple of those bug fixes and then I'll try some tune-ups to the meshing UI then I'll be able to release a new beta with these improvements.
2318.5 In reply to 2318.4
Although, as you say, technically the mesh is there, in reality it does have 'problems' rather than 'errors'. This means correcting it in the next app down the line. Especially if you want to use the MoI output as a basis for any sub-d work.
So anything you can do to reduce the problem areas would be great :-)
Tony
