WIP - Hydraulic Connector
 1-18  19-38  39
2284.19 In reply to 2284.17
"Having a panel where you sometimes need to do one click on a tab to activate a different palette is a whole lot better workflow than trying to scroll a big UI container up and down to find the right UI."
I would agree with this, its frustrating for me with other applications to have to scroll up and down palettes to see what is in them, seems kind of self defeating and disorientates the palette space.
The answer is to make a work space that is customizable, Sketchup is a very very good example of this, but I would agree that other things should have a higher priority, groups and layers for example!
I have the impression that you dont want to use right click menus but I think they will be almost essential to keep the organisation of palettes simple, no?
my demo runs out in a few days but I will be buying a copy very soon.
2284.20 In reply to 2284.18
> People who use MoI on less than a 15inch screens then?
Again, many laptops have smaller than 15 inch screens.
For example just a very quick survey of new DELL laptops here - I count 5 out of 11 models on that page have a screen of less than 15 inches in size.
Actually smaller sized laptops are currently one of the most popular types.
re: Icon size - you can actually change the size of the icons without tweaking the UI files, for that go to Options / General and use the UI size slider to scale the UI to your preference.
2284.21 In reply to 2284.19
Hi Paul,
Yeah easier customization would definitely help with that.
But it tends to be a difficult area to implement especially when the UI is different than the kind of "standard toolbar UI".
Early on in MoI's development I had to make a decision whether to spend a lot of time working on UI drag/drop type customization, or instead to work on developing just a single UI that was as good as I could make it, and I chose the latter. I would definitely make the same decision again. If I had forever to develop it, it would have been possible to do both, but my time is limited so I have to be careful which big projects I undertake. Now that the UI is really well defined it will probably help to make it more feasible to do a more targeted type of customization than it would have been trying to focus on customization earlier in MoI's lifetime.
Customization actually tends to be an area used by a fairly smallish number of users. For example in Microsoft Office, after gathering a substantial amount of data on how people use Office, they found out that less than 2% of Office sessions ran with any kind of customized UI:
http://blogs.msdn.com/jensenh/archive/2006/06/27/648269.aspx
That's one reason that made it possible for them to shift to a much different UI model in Office 2007 which actually has a lot in common with MoI, including actually losing a lot of customization type functions.
I think that I will be adding some right-clicks in some strategic areas for advanced commands. But it tends to make things pretty hidden so I try to avoid it a lot for basic functions.
In the future as I add more functions the plan is to mainly add new palettes, but that will be collapsed by default. To see what this will look like you can actually collapse a palette currently by clicking on its tab again after it is already active.
So there will be tabs like "Render", "Dim", "Analyze", etc... below the current palettes but with them being collapsed by default they won't add hardly any complexity to the top level UI.
2284.22 In reply to 2284.20
"re: Icon size - you can actually change the size of the icons without tweaking the UI files, for that go to Options / General and use the UI size slider to scale the UI to your preference."
I did not know that one was there! WOW!
And you say that having those parts separated so that they can be open at the same time-- is "difficult"?
Maybe I am missing something. (Running around in circles?)
Brian
2284.23 In reply to 2284.22
Yes - because separating them would cause problems for people on smaller screens, the separated UI would be larger than their screen and force a scroll bar to appear.
Sorry I wasn't clear - the hard part is not just doing it, the hard part would be avoiding the bad consequences and negative side effects from doing it.
So to do it properly would really need a kind of customization mechanism, like making it so you could grab a tab and drag it around to place it where you wanted.
Then there would be a default setup the same as the current one that worked well across many different sized screens, but if someone had a larger screen like you do, then they could more easily change the UI to suit it.
But that will require a lot of work to make that kind of system, I don't think that I will be able to get to that anytime too soon.
EDITED: 2 Jan 2009 by MICHAEL GIBSON
2284.24 In reply to 2284.23
Sorry Michael
Is this, really, too hard an add on option, using that other option you just gave
me before--- thats in the app?
Brian
No need to reply.
Size: 184.1 KB, Downloaded: 85 times, Dimensions: 1920x1200px
2284.25 In reply to 2284.24
> other option you just gave me before--- thats in the app?
You mention "using that other option you just gave me before" - are you talking about the UI size option here? What you show there is something totally different than changing the size of things, so no those are not really connected in any fashion.
What you show there a big re-organization of the UI, things belonging to different groups and sections, etc... - that kind of major re-organization is not particularly easy to do with a checkbox type option if that is what you were asking about?
Once V2 is complete probably someone will cook up a customized UI with that kind of thing in it, just like is available for v1 already. But it is pretty hard to do that currently with v2 when other changes are happening for each beta release.
If you want to change the current beta, it is actually possible to set it up the way you show there if you edit the UI files under the \ui subfolder inside of MoI's main installation folder. Look for the sidepane.htm file, when you open that up in notepad, you will see various tags such as <moi:PaletteBody> <moi:CommandButton> , etc... - if you re-arrange the structure of these in that file it will also re-arrang the structure of the UI, I mean the UI comes directly from that file.
2284.26 In reply to 2284.25
Ok Michael.
That latter part is all double dutch to me.
Scripting stuff--if thats what it is---is not in the realm of the majority of 3D users to whom I promote MoI I would think either.
Why, with all the apps I have and use, would I need to learn this---all of a sudden?
Another world!
Sorry, don't waste your time.
Brian
2284.27 In reply to 2284.26
Well, you wanted this to be a really high priority - if it is that big of a priority to you that is the way that you could make it happen right now.
Otherwise maybe after v2 is complete someone will do a different UI pack for it.
I wish I had enough time to make all features that everyone wants all be at the same priority and all happen at the same time, but I'm sorry I just have not been able to make that happen.
2284.28
Very cool model
2284.29 In reply to 2284.6
DannyT,
On behalf of Grendel, I can answer since I too work in the field.
Generally, bare stainless to ocean will be 316, 17-4, or 2205 duplex. Differences in grades particularly with 17-4 and duplex, and usually with 316 you would find 316L because the L designates a low carbon content for improved weldability. However reduced carbon can reduce strength but increase ductility/charpy characteristics.
- Jason
http://www.jasedesign.com http://www.nurbsandpolys.com http://www.cgpipeline.com
2284.30 In reply to 2284.29
Thanks Jason for the help, missed that. Answered part of the question but not the other ;P)
2284.31 In reply to 2284.29
Thanks for that answer Jason, actually forgot that I asked it so no sweat Grendel :)
The reason I asked then is that we use a lot of stainless in the line of work we do but we use Martensitic stainless steels mostly 420 series, machined then hardened to about 48 Rc, the problem lately is that we've had a few failures and we discovered it is due to intergranular corrosion.
Have any of you guys, Jason, Gredel, experienced this with the products you guys design being under the ocean and exposed to the salt.
2284.32 In reply to 2284.31
It's been a few years for me but a Marine Construction company I used to work for did a job where we had installed a fuel line under a pier using stainless hangers. The steel was speced out properly but there was something with 'WHERE" we got it that was the issue. Supposed to be the saltwater grade stuff and started corroding before we were done hanging it! Produced in a country where the spec stamp was penciled in I guess. Those company purchasing agents can make or break the best builders!
2284.33 In reply to 2284.32
Nice looking details on the connector.
2284.34
DannyT I have not used that material in any of our components. We stick with the 316 and Duplex for just about everything.
2284.35 In reply to 2284.34
400 series is not suitable for subsea or ocean, but it more used for surgical steel because of the hardening capability.
400 series does not contain nickel, and generally for stainless characteristics you are looking for combinations of chromium and nickel but with 400 series it is chromium that gives the corrosion resistance. Also, 300 series are not magnetic (a trade of austenitic steel).
What is it you are designing and the constraints? The other problem with 300 series SS is the fact that they require oxygen to work, that is to say they need oxygen for the surface oxide to protect the metal, without it the steel will corrode, so 300 series is susceptible to crevice corrosion.
For stainless steel informatin, you can try this site: http://www.ssina.com/index2.html
If you want, you can contact me at jason (at) jasedesign (dot) com
- Jason
2284.36
Thanks guys, interesting stuff !
Thanks for the chat invite Jason, but to chat to you about work......zzzzzzzz, I'd rather chat about what the weather is like down there and maybe modelling techniques :)
The original question was just out of curiosity.
2284.37 In reply to 2284.36
Danny, the invite was for whatever. Or catch me on NaP for modeling stuff.
- Jason
2284.38
Here is a 3d print of the connector using a Z-corp 650. This is straight from the machine and has not been sanded or dipped yet so the it's a little rough and the colors become brighter after dipping. The connector is about 7 inches tall, it's fun to have access to a machine for this stuff. Stuck my watch in their for scale.
EDITED: 21 May 2009 by GRENDEL
Show messages:  1-18  19-38  39
