Cplane problem/request
All  1-15  16-20
2270.16 In reply to 2270.14
Michael
>Does another checkbox that says: "Orient ortho views" make sense?
Yep, I think users will understand this.
Manz
>The views could be to user Cplane, but curves drawn in the ortho views projected to the relative world planes.
Thats how it currently works ?
2270.17 In reply to 2270.15
Hi Steve - sorry I'm not following that, could you describe it a bit more?
Maybe what you are talking about would be if the 2 checkboxes were always visible (instead of the second one disappearing when you unchecked the first one), and you disabled "Apply to all views" (so the grids in ortho views stayed as their default world planes), but enabled "Orient ortho views" so that the view directions do shift to be relative to the custom cplane?
If you could describe a bit about the scenario where that would help out, that might help me understand it better.
2270.18 In reply to 2270.17
I was thinking of the "ProjectOsnap" in Rhino, but a little more simplified. As example. A drawing can be set up on a custom Cplane with "apply to all views", with an option to "project", then, rather than the curves being drawn on the user Cplane, they are projected to the world plane.
- Steve
2270.19 In reply to 2270.18
Hi Steve,
I'm not sure which world plane they would project on to?
A user cplane is not restricted to be similar to the original world plane - they can easily be flipped around in some totally different direction. For example it would be possible for a relocated "Top" view to be looking down right at the edge of the normal "World Top" plane.
So it's not really clear to me how that would work...
The other part is that you seem to be talking about curves being projected - would that mean that a circle that was being drawn would instead project to an ellipse as the end result? If so then that is not something that can easily be set up by just changing how points are picked, the circle command for example only currently knows how to construct a circle, not an ellipse. So that would probably require changes to every command, making it a rather difficult amount of work I'm afraid.
2270.20 In reply to 2270.18
Steve
Couldn't you place a rectangular surface or similar object on the world plane as a temporary object. Draw you objects/curves on the cplane and then use the project curve tool ?
~Kevin~
Show messages: All  1-15  16-20
