Need Advice Array object
All
1-4
5-11
Anis
20 Dec 2008 (5 of 11)
2262.5
In reply to
2262.4
Hi Michael....
> MoI does not currently have an array command to replicate an object across a curved surface.
Yes I know, but I want to try with existing features :)
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Michael Gibson
20 Dec 2008 (6 of 11)
2262.6
In reply to
2262.3
One thing that you could try - get some curves below your surface:
Use Construct / Curve / Project to project them on to the surface:
Draw a sphere at the end:
Use Transform/Array/Curve to replicate it:
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Brian (BWTR)
20 Dec 2008 (7 of 11)
2262.7
In reply to
2262.6
Anis
I think you will see that this first approach needs a bit of finessing, BUT, I think the approach is right.
Hooray for Arrays!
Brian
PM me if you want the 3dm file.
EDITED: 31 Dec 2008 by BWTR
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Anis
20 Dec 2008 (8 of 11)
2262.8
In reply to
2262.6
Thanks Sir, I will try and post the progress later.... ;)
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Anis
21 Dec 2008 (9 of 11)
2262.9
In reply to
2262.8
I know its still far from perfect, but at least this method is working.
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Brian (BWTR)
21 Dec 2008 (10 of 11)
2262.10
In reply to
2262.9
Variations on the original theme.
Brian
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Brian (BWTR)
22 Dec 2008 (11 of 11)
2262.11
In reply to
2262.10
More variations--can not get to sleep so just fidling with various ideas for fun.
Used the projection of a spiral for the Array path.
Brian
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Reply to All
All
1-4
5-11
