Temple
2251.1
Hi all ..
Attached is a model of the basic framing of the central room of a Tibetan/Mongolian (influenced) temple I am currently preparing the working drawings for. It will be built in the spring of 2009. It is modeled with MoI (with a little help from Rhino for some splits). I completed the original conceptual design last year using Rhino and Flamingo as I had not discovered MoI yet.
The framing shown on only one quadrant of the roofs is for illustration for the building contractor ... a complete framing plan in perspective view would be pretty confusing but two dimensional drawings cannot make it very clear by themselves.
I thought it might be interesting to post a model with all straight lines (in contrast to most of the postings here).
cheers and an early happy solstice ... it is -20 C here today.
eric
Size: 84.6 KB, Downloaded: 171 times, Dimensions: 792x554px
2251.2 In reply to 2251.1
That idea looks like a great new challenge for me in MoI.
In Adelaide our temperature today will be about +24C---cold for us at this time of the year when we often get 40C+ summer temperatures.
Brian
2251.3 In reply to 2251.1
And you will have a more detailed fine volume if you disable Hidden lines ;)
2251.4 In reply to 2251.3
Yes, that's true, Pilou
On the other hand that's one of the things I like about MoI. This is a reference drawing for the carpenters and I want them to be able to see the hidden lines to understand the construction more clearly.
If I wanted a complete solid I would use a rendering tool.
Thank you for your comment. :)
eric
2251.5 In reply to 2251.1
Hi Eric, it's a cool design and a great result, it looks like you put that screenshot script to some good use there!
I hope you can post some photos of the construction later, it is always fun to see that stage too.
2251.6 In reply to 2251.5
Eric
I guess you and my carpenter son would shudder in disgust at my effort.
But, on the basis that this example is the hard part, I was quite pleased at how MoI worked---as usual!
Brian
EDITED: 31 Dec 2008 by BWTR
2251.7 In reply to 2251.5
Hi Michael
Thanks for your comments. The screenshot script is great.
I will post some pictures of the construction along about June.
cheers,
eric
2251.8 In reply to 2251.6
Hi Brian ..
It works as long as you don't have a snow load. :)
cheers,
eric
2251.9 In reply to 2251.8
Eric
Whats a snow load?
Some of us have never seen snow!
Brian
(More, bigger, stronger purlins and joists as required!--- Array, Array!)
2251.10 In reply to 2251.9
Hi....
I never touch or see real snow before either.... :(
2251.11 In reply to 2251.10
Go to your freezer, scrape some of that fluffy white frosty stuff off from around the cube maker. Same difference! :)
2251.12 In reply to 2251.11
Burr, the Hawaiin Snow Man!
Brian
2251.13 In reply to 2251.5
Hi Michael ..
I will post pictures next year but in the meantime, this was an earlier design study using Rhino and Flamingo.
The final results should look something like this
cheers
eric
Size: 112.1 KB, Downloaded: 91 times, Dimensions: 804x431px
2251.14 In reply to 2251.13
Hi Eric, will the building be used as an actual Buddhist temple?
It looks great! It will be a lot of fun to see the construction too.
2251.15 In reply to 2251.14
Hi Michael ...
Yes ... it is in the Kootenay mountains of British Columbia, Canada. They bought a big house and some land a few years ago and the original work included renovating the house and adding to it to create a meditation retreat and teaching center. The teacher (Rinpoche Zazep Tulku) hopes to have his 60th birthday celebration on the floor of the new temple next spring (2009) ... with a following big work retreat scheduled to put up the timber frame. I will get pictures of the process.
cheers,
eric
