Feature request and a few other questions
All  1-9  10-13
2249.10 In reply to 2249.9
> The 24" inch screen is new for me--but it only accentuates
> the better workings of the layout option suggestions.
The problem is that works better for you on a 24" screen will appear weird to other users on a 19" screen.
Those users would perceive an odd slight shift of what is normally left aligned to the right, with no benefit to them... The result for those users is just negative with nothing gained.
That's the kind of problem that tends to happen if I try to totally optimize for just one certain screen size.
It's a tough problem, I kind of have to limit some things so that MoI is usable for people working on laptops or on screens without giant monitors.
> It was suggested a week or so ago that the option for
> having all the current basic things open at once would be good.
Yes, but once again it would be good for people with large monitors and cause problems for people who have smaller monitors.
I also described some of the other issues back then - filling up the whole side doesn't allow very well for expansion of new items in the future.
I would definitely like to make more options to make it easier to re-arrange the UI in the future!
But currently more modeling and 3D oriented tools are a much higher priority than that.
It would be cool if I could make everything happen all at once, and make advances in 3D modeling functions and in UI re-arrangement functions all at the same time. But I haven't figured out yet how to do more than 24 hours of work in a day, sorry! :)
2249.11 In reply to 2249.6
<It tends to be difficult for me to know in advance how long it will take to finish any particular piece. It usually takes me a while longer than I initially expect to drive it to a high level of quality and not have many bugs, have a nice UI design, etc... So it just tends to be pretty easy for any guess at a timeframe to just be wrong, sorry! But my current guess would be maybe 2 weeks for the next beta and final v2 sometime around March or so.
I guess I could put one out earlier than that if you would like a version that crashed a lot and generally didn't behave well... Do you think that would be better to have stuff out quicker but less quality?>
Hi Michael ...
My two cents ... quality / not quicker.
There is nothing much more frustrating that a really buggy beta. True that a beta is a beta and there are always opportunities for improvements or the fixing of the unexpected but I prefer that betas and releases be as bug free as possible.
Keep up the good work and thanks again for being so responsive to your users,
eric
2249.12 In reply to 2249.1
Dan:
>>Question 1: When offsetting a curve, such as ellipse or freeform, the resulting new
>>curve has so many more control points, especially along the tighter bends, even though
>>the newer curve doesn’t seem to be that much more complex than the original. I can often
>>delete many of these “extra” control points without any perceivable effect on the curve at all.
>>Why? I’m just curious. If the answer is too complex you need not answer.
Something to try :- Extrude a surface from the base curve, offset the surface, then copy/paste extract the edge you need. This is a long winded way of offsetting the base curve but often reduces point count. Another option would be to model using line/arcs if possible this will help your case dramatically and keeps geometry much simpler for further feature editing ;-) (Micheal is 'simplify curve' or the list?)
EDITED: 15 Dec 2008 by KARTER
2249.13 In reply to 2249.12
A future Forum post?
" A survey of the UI options available in the current version of MoI indicate that 90% of MoI users prefer the, highly acclaimed, 2008, "Brian" collection.
The survey also found 10% of MoI users did not know UI options existed."
Brian
(Always hoping for my 5 minutes of fame!)
Show messages: All  1-9  10-13
