Feature request: change export units and auto scale on export
All  1-14  15-18
2241.15 In reply to 2241.10
>> Do you mean you are manually scaling by 25.4 ? Normally it is intended
>> that you should be able to switch your unit system from Inches to Millimeters
>> which will apply this scale factor for you.
Opening the STEP file in Rhino/MoI auto sets the scaling to inches (no problem there). What I've done in the past is change the unit (and let it scale) and works great. I hate working in mm however (since any changes are relayed in inches...the original STEP file is in inches) as well as "add on geometry" is relayed in inches. I'd prefer to keep the geometry in inches...so I'm just picking at "nits"...
>> There is one currently available for OBJ format export - you can set that under
>> Options > Import/Export > OBJ options > Scale Factor.
I looked for that -- musta missed it! That'll probably do the trick, a question on that however...does it translate the scaling before or after meshing? This is getting into a whole other realm, but I do know from past experience there is a HUGE difference in output (with our geometry at least) between a mesh in inches vs millimeter (hopefully I'm not blurring Rhino and MoI experiences).
>> It should be remembered automatically while inside the same program session.
Single session it works as advertised, for some reason we're constantly dumping in and out of MoI and other apps so a tween-session/default value would be awesome!
Thanks Michael!!!
2241.16 In reply to 2241.15
Hi AW,
It scales after meshing is done - the scaling is applied to mesh vertices just as they are being written into the OBJ file.
Please let me know if that does not handle what you need!
There normally shouldn't be a difference in MoI, when you are only using the "Angle" parameter, which is independent of size - unlike some other parameters such as "Divide larger than" which take a distance value (distances are sensitive to scale factors but angle measurements are not).
But there is one bug that I have fixed up for the next v2 beta that did affect polygons that were pretty small in size though (like around 0.001 units in size).
In the next v2 beta, there will be some new values you can set in the moi.ini file to control the initial default values of the meshing options.
These will be in the moi.ini file under [Mesh Export] :
[Mesh Export]
Angle=
DivideLargerThan=
DivideLargerThanApplyTo=
AvoidSmallerThan=
AspectRatioLimit=
So setting whatever you want there should handle this part for you in the next v2 beta.
2241.17 In reply to 2241.16
I'll check this out -- again, it mighta been a Rhino thing, the "mesher" you have in MoI has MUCH better output so hopefully those little anomalies won't show up in the first place. :D
>> In the next v2 beta...
Plus the speed of the new meshing routines! Drooling in anticipation!
Cheers!
AW
2241.18 In reply to 2241.17
Hi AW,
:) You're not going to even believe how much faster it is.
Show messages: All  1-14  15-18
