Shell one-sided object
 1-14  15-27
2228.15 In reply to 2228.14
Thanks Paolo, I'll check it out when I get home.
/Lars
2228.16 In reply to 2228.1
I had a play with this.
Shelling the strip was OK but I had problems trying to add fillets to all the edges, so instead I created 2 solids using sweep (2 rails), then booleaned out the holes using cylinders. I was then able to add fillets to all the edges.
EDITED: 3 Aug 2009 by MANZ
2228.17 In reply to 2228.16
manz perfect job :)
ciao
torolf
2228.18 In reply to 2228.17
Well I am lost!
Have tried everything and I have no idea how you get from A to Z in this idea.
Brian
(I think it will keep me awake in bed tonight even so----should I make a movie?--2 cameras?)
2228.19 In reply to 2228.18
I have attached the solid model with the construction curves, maybe it will help?
Regards,
- Steve
test the SKP format export : ok! :)
2228.21 In reply to 2228.20
Thanks Steve.
I should have been in bed 3 hours ago!
Will look at --later
Brian
2228.22 In reply to 2228.16
Nice one manz!
Here's another -
/Lars
2228.23 In reply to 2228.11
Hi Michael, haven't figured out how to use the MakePeriodic command yet, it produces this result:
But I'll keep tryig, since the problem obviously is with the surface normals.
/Lars
2228.24 In reply to 2228.23
Hi Lars,
Hmmm, well that is a weird result. Is the surface possibly trimmed?
This looks like a different model than the one you posted previously? If you can post a .3dm with this surface (before doing MakePeriodic on it) I can take a look at it to maybe tell what is going on there.
2228.25 In reply to 2228.24
Hi Michael, that is really too kind of you. It's a simpler model without the holes, just the basic geometry.
/Lars
2228.26 In reply to 2228.25
Hi Lars - I see what the problem is.
I actually gave you some bad advice, I forgot that you had a moebius topology here. Sorry about that!
A periodic surface has the kind of smooth closure that you need (the surface is defined with a set of points that overlap with one another in the closure area) but a periodic surface is usually set up in NURBS such that the surface is joined with the same sides to the "outside" where it is touching itself.
Like for example if this is the UV layout of a typical periodic surface, the 2 points circled in red would be touching one another in 3D along the seam.
But for a moebius topology I guess you need a kind of special case periodic surface that would match things opposite from that, like match one corner to the one across the diagonal from it instead of straight across. I don't know of any existing command that would do that, it would take some specialized code.
I don't think that it is going to be very easy to get a proper smooth single surface out of this thing since NURBS is not generally set up with this kind of topology in mind.
Probably your best bet to produce the final form would be to cut back the area around that seam a bit to make an opening, then use Blend to put in a smooth piece. That should have a lot better chance at giving a thickened result I think.
The way you would do that is in Rhino use ShowEdges to find the seam edge, then use Split with the Isocurve option to place the cut lines near there, to create the opening. Then I took it into MoI, did a Blend with Continuity:Curvature option, then joined the pieces, then Shell, and then there is a problem with the result where there is one of those internal walls created since Shell is not expecting this kind of thing, so you have to use Edit/Separate, delete the internal walls, then rejoin and finally there is what seems to be a proper solid result which I've attached here (doublemoebius_blend_3dm.zip)
Hope this helps!
2228.27 In reply to 2228.26
Thank you very much Michael, I will give this a try.
/Lars
Show messages:  1-14  15-27
