Mouse setup
All  1-3  4-7
2225.4
Nor am I sure that SketchUp is better, but working with both the software I like to use the mouse in the same way and I was wondering if a script could be resolved.
Nicola
2225.5 In reply to 2225.1
Hi Nicola, yes it is possible to switch to rotate by the middle mouse button by changing a setting in the moi.ini file.
First shut down MoI and then open up moi.ini in a text editor like notepad.
You can find moi.ini here (on Windows XP, on Vista it is slightly different):
C:\Documents and Settings\ [your login name] \Application Data\Moi\moi.ini
Inside the [View] section there will be a setting:
SwapPanRotateMouse=n
edit this to say:
SwapPanRotateMouse=y
Then when you start up MoI it should be set up so that it will rotate by the middle button and pan by holding down the right button instead of the normal behavior.
2225.6
Michael Thanks for your help, as always
Nicola
2225.7 In reply to 2225.5
<Then when you start up MoI it should be set up so that it will rotate by the middle button and pan by holding down the right button instead of the normal behavior.
In Sketchup it's rotate by the middle button "pressed" and not "only rolled"
is it the same?
Edit : yes it is :)
EDITED: 7 Dec 2008 by PILOU
Show messages: All  1-3  4-7
