Image in Views
2220.1
When I bring in an image and I don't want to see that image in the 3D view we select Show in>Ortho only, but when I change the 3D view projection to parallel the image appears in the view and I can't get rid of it. Is this a bug ?
2220.2 In reply to 2220.1
Hi Danny,
its ok for me both in v1 and v2.
or maybe I am not understand your question...
2220.3 In reply to 2220.2
Hi Anis,
In V2, place an image in the front view, while still in the 'Image' command, pick 'Ortho only' in the 'Show in' drop down, pick 'Done'.
You should have the image showing in the front view only. Now go to Options > View > 3D view projection and change from Perspective to Parallel, what happens ?
2220.4 In reply to 2220.3
Got it, use parallel then the image appear.
another think, when I click "restore defaults" nothing happen on the 3d projection.
2220.5 In reply to 2220.1
Hi Danny - yup that's a bug, thanks for reporting it!
Technically the 3D viewport with a parallel view set is an orthographic projection, but really that "ortho only" there was intended to mean "Top, Front, Right views".
You may run across a few similar lingering bugs like this where the code assumes that a view that is not perspective is one of the Top/Front/Right views, which used to be the case before the parallel view mode for the 3D view was added.
It's a very simple fix, but there are 2 choices that I have for what should happen.
One way I can set it up is so that when that option is enabled, the image will not show up at all in the 3D view in any circumstances.
The other option is that I can make it show up in any "Plan ortho view", which would include showing it in the 3D view when that was set to a Parallel projection and it was looking straight down on the construction plane like the Top view.
Do you have any preference for one behavior over the other?
2220.6 In reply to 2220.5
For me, not show up at all in the 3D view in any circumstances when that option is enabled, that's the reason I enable it, otherwise I would choose All views.
2220.7 In reply to 2220.6
Hi Danny, I've got it fixed up to behave like that for the next beta.
