Skp & decimal number
All  1-5  6-15
2207.6 In reply to 2207.5
Hi Pilou - use Tab if you want to also enter a value for the next field, as it will commit the current value and then also move keyboard focus to the next field so you are ready to type in something there as well.
If you only want to commit a single value, then push Enter.
> So now all is fine except that in Sketchup it's write
> 32.2400 cm
I've got that part fixed up for the next beta.
2207.7 In reply to 2207.6
< currently MoI does not export the number of decimal point display precision to the SKP file, do you think that it should?
Seems you will obtain perfection in the next beta ;)
Using Tab for valid was not so evident / against Click mouse :)
EDITED: 2 Dec 2008 by PILOU
2207.8 In reply to 2207.7
> TAb = left hand, mouse click on case = right hand
Normally Enter is the common way to do such things, which should work here as well.
But Tab can also be used for the same as Enter plus moving focus to the next field.
2207.9 In reply to 2207.8
Tab = left hand, mouse click on case = right hand
(I enter my number on the numeric keyboard with my left hand when i had the mouse in right hand ;)
So Tab was not under my hand :)
This explain that ! No thinking of the Tab key!
2207.10 In reply to 2207.9
Hi Pilou, does your numeric keyboard have an "Enter" key?
You should be able to use that one as well.
If your hand is on the number pad part of the keyboard, there should normally be an "Enter" key right near your hand as well. That one may be easier to think of to hit than Tab.
2207.11 In reply to 2207.10
yes it has :)
but that is ending the current inside (and not the all if I move the click mouse on the 3 changes x,y,z)
the cyclic Tab is the only great key (or future mouse click if this one can be possible :) (if not, that is not a big problem)
Another thing : what about pen Graphic's users when they want modify the x,y,z object ?
I don't find the Numeric panel?
2207.12 In reply to 2207.11
Yeah, in this case I decided to experiment with a type-in only control for this particular piece of UI.
It just seemed a little strange having the pop-up panel come up in this case, partly because it is a already a small panel and having a pop-up on top of another pop-up is slightly odd.
If I hear a lot of feedback from users that they really need to use this particular thing without a keyboard I'll try to figure out some way to enable it in the future.
2207.13 In reply to 2207.12
If the future is like this you will be obliged! :)
And that will be that!
2207.14 In reply to 2207.13
No, not necessarily.... A device like that will also need a kind of on-screen "virtual keyboard" for general purpose typing tasks.
For example I don't expect for MoI to try and pop up a complete alphabet keyboard of its own to enable typing in a file name, that is something better suited to the OS supplied virtual keyboard.
Similarly, in certain areas where I'm kind of expecting that a larger number of digits may be typed in, it may possibly be better overall to rely on the OS virtual keyboard for those particular areas.
It is bad to need to pop it up for very frequently used things, but for things that are less frequently used and at the same time more typing intensive, then that is a good fit probably.
2207.15 In reply to 2207.14
So wait & see :)
Show messages: All  1-5  6-15
