WIP - Space Hangar
All  1-4  5-20
Space Opera!
2191.6 In reply to 2191.2
Question for Paqs Modeling technique. Does everythng have "thickness" as in real life, or do you just use "surfaces" in some areas.
In other words, if you had say a "heat gaurd" that covered an exaust pipe, in reallife it might be 3 mm thick chrome. You could design sheet of 3 mm thick material or just make surface shape, no thickness and apply material at render time..
Any insight is appreciated.
Burr
2191.7 In reply to 2191.6
Thanks for your comments everyone :)
@BurrMan
No really sure if I really get your question, but yes everything has thickness, at least everything coming from MoI, otherwise I would have normal problems.
That's said, as you are talking about 3mm thickness stuff, I'm not really sure of which part of the models you are talking about :S (I don't rememer creating such a small surface offsets)
2191.8 In reply to 2191.2
PaQ! nice work!
I like the way you express the enormity of your scenes without any reference to scale, must be the camera angles :)
Thanks for sharing
2191.9
Amazing!
What a gorgeous work.
Congratulations! I love those kinds of universes :-)
2191.10
Paq, what did you render those in?
If I had to guess......Modo perhaps?
2191.11 In reply to 2191.7
Not so much this particular model. More your mindset when you create models.
To try and be more simple in my question:
If you had to do say a Car exaust pipe, the metal of the pipe would in reality be .0625 inches thick. Yet you could model it with just a surface tube. Heres a picture of the 2 different ways.
Thanks.
2191.12 In reply to 2191.11
Hi PaQ...
Just Wow !!!!
What is your computer spec ?
2191.13
Hello there, thanks again for your kind words :)
@TwinSnakes
No, I'm back into lightwave for this project, all this stuffs are made for a short movie.
The new animation cache system for the global illumination is really nice :)
@BurrMan
Ok got it, so the reply is the same, yes everything has thickness, I only work with solids to avoid
polygon normal problems when exporting the model in poly.
@Anis
A quad xeon 3.0 ... but it doesnt matter as MoI only use one core I guess :)
2191.14 In reply to 2191.13
Hi PaQ...
And you will post a part of the movie also.... :)
2191.15
Gorgeous and inspiring PaQ!!
2191.16
I want to be like PAQ when I grow up! :-)
Inspiring work!
-Will
2191.17
Michael, can't wait the objects manager system :O)
EDITED: 3 Feb 2010 by PAQ
2191.18
Michael, with WIPs like that, I can't wait for PAQ to get the Object Management system! :-D
-Will
PS - I'll be straight once I'm able to name and export my surfaces! ;-)
2191.19 In reply to 2191.17
Hi PaQ, wow that is looking great!!
Yeah I'm guessing that some object management tools would be of use for that! :)
2191.20
Now this is just freaking awesome!
Show messages: All  1-4  5-20
