Moi and TopMod Import OBJ
All  1  2-3
219.2 In reply to 219.1
Hi Pilou!
> But maybe TopMod is not tailor-made for import Obj in Ngones! :D
It looks like it does work with some N-gons, but all the example ones it has seem to be all more simple convex n-gons (where any two points inside the polygon do not make a line that goes outside of the polygon). So maybe it is limited to only more regular shapes for each polygon.
Those are some really cool sculptures in their gallery!
> Ps Why Pan and Rotation Icones Arrow in MoI seems to
> produce the Inverse movement ???
> (like if you are in a plane :)
By default they function as if you are manipulating the view point - Moving to the left moves the eye point to the left for example. If this seems reversed to you, you can change it by going to Options, then Rotate/Pan/Zoom options, then check "Reverse rotate button" and "Reverse pan button".
> Is there a way to reset 3D wiew and grid to the start status position?
> (useful when you have made some rotations :)
You can do this if you hide all objects, then push the "Reset" button. If nothing is visible when you do a reset, it will reset to the initial start position.
219.3 In reply to 219.2
Thx for these 2 cool tips and tricks & explanations :)
Show messages: All  1  2-3
