Moi and TopMod Import OBJ
Moi Export Obj ---> TopMod Import Obj
Just a little try with this free incredible Topological mesh Modeling: TopMod
http://www-viz.tamu.edu/faculty/ergun/research/topology/
As you see all works fine except for the export in Ngones :)
But maybe TopMod is not tailor-made for import Obj in Ngones! :D
Ps Why Pan and Rotation Icones Arrow in MoI seems to produce the Inverse movement ???
(like if you are in a plane :)
Is there a way to reset 3D wiew and grid to the start status position?
(useful when you have made some rotations :)
219.2 In reply to 219.1
Hi Pilou!
It looks like it does work with some N-gons, but all the example ones it has seem to be all more simple convex n-gons (where any two points inside the polygon do not make a line that goes outside of the polygon). So maybe it is limited to only more regular shapes for each polygon.
Those are some really cool sculptures in their gallery!
By default they function as if you are manipulating the view point - Moving to the left moves the eye point to the left for example. If this seems reversed to you, you can change it by going to Options, then Rotate/Pan/Zoom options, then check "Reverse rotate button" and "Reverse pan button".
You can do this if you hide all objects, then push the "Reset" button. If nothing is visible when you do a reset, it will reset to the initial start position.
219.3 In reply to 219.2
Thx for these 2 cool tips and tricks & explanations :)
