fbx export hang
All  1-2  3-4
2188.3 In reply to 2188.2
yes it happens after I click the ok dialog. I'm emailing you a file, thanks !
2188.4 In reply to 2188.3
Hi lwan, thanks, I got the file.
However, over here it seems to work fine, I sent back an exported FBX file to you.
Are you using the new Nov-21 beta release from here: http://moi3d.com/beta.htm , or are you still using the old Sep-21 beta version?
The old Sep-21 version had some bugs when saving to a filename that had non-ascii characters in the folder or file name.
That may be possibly what you are running into, but I thought I had got that fixed up for the new Nov-21 beta.
If you can verify which beta you are running, and also possibly see if saving to a very short and plain folder and filename like c:\test.fbx works, that would help me narrow down the problem, thanks!
Show messages: All  1-2  3-4
