fbx export hang
2188.1
Hello,
is it known the fbx exporter hangs quite often (forever, no file outputed) ?
2188.2 In reply to 2188.1
Hi Iwan, no I have not heard of that problem yet.
Do you have an example file that you can send to me so I can reproduce the problem over here? You can send it to me at moi@moi3d.com if you want to keep it private.
Does the hang happen after you push "Ok" on the meshing dialog?
Or are you seeing a problem before the meshing dialog is displayed?
2188.3 In reply to 2188.2
yes it happens after I click the ok dialog. I'm emailing you a file, thanks !
2188.4 In reply to 2188.3
Hi lwan, thanks, I got the file.
However, over here it seems to work fine, I sent back an exported FBX file to you.
Are you using the new Nov-21 beta release from here: http://moi3d.com/beta.htm , or are you still using the old Sep-21 beta version?
The old Sep-21 version had some bugs when saving to a filename that had non-ascii characters in the folder or file name.
That may be possibly what you are running into, but I thought I had got that fixed up for the new Nov-21 beta.
If you can verify which beta you are running, and also possibly see if saving to a very short and plain folder and filename like c:\test.fbx works, that would help me narrow down the problem, thanks!
