Request - A tube tool with on surface offset.
 1-12  13-32  33
2187.13 In reply to 2187.12
Rotate widget. Nice!
I just did a sweep test and it followed the path through some surfacing turns exactly as expected, then right at the end point, closest to you in the picture, slide over on its side and sunk in to surace.
Is there something about that last point I picked that controlled this? Is there anything in this method that controls the "up" of my path or is it automated?
2187.14 In reply to 2187.13
Hi Burr, oops I forgot about the twisting.
There is a Twist: option in Sweep which allows you to choose between the standard minimal gradual twist, or a twist that only rotates around the world z axis.
Neither one will do a "Twist only around some various different normals of surfaces that the curve happens to come close to" though.
Aside from the twist parameter though you can add in additional profiles to control it.
Like if you repeat the circle positioning at the end so that then you have 2 circles, that would enforce the profile position at that area, possibly doing that at that spot and maybe 1 or 2 others would do the trick.
That would be a benefit of having the rail curve itself offset from the surface though rather than the profiles - it would be basically immune to the twisting, since the twist would be around a circle's center point instead of its side-quadrant point. But probably harder to set up the central rail curve though.
2187.15 In reply to 2187.13
Hi Burr, just another note:
It's nothing about that last point - the twisting is due to the way the rail path travels around in 3D instead of being planar.
When a sweep profile curve is following a 3D path, there is a kind of gradual twist that happens to it as it follows up and down humps, etc... - it's something that helps each new positioned curve to be as minimally different from the previous one as possible.
If it didn't do that, it would tend to swing around more suddenly at some spots as it changed in orientation.
The "flat" twist option does it differently and only rotates around the world z axis. But there you will see the kind of sudden large jumping for paths that have a tangent that approaches that z axis direction.
2187.16 In reply to 2187.10
Yes I can understand having a realtime feedback for this kind of tool require much more power computing that simple polys.
About the offset :
I get the circle offset position before the sweep, however it only works for ground plane, but not when the driving curve has to touch different object, like the first image sequence I post, or for the little example here :
>> Offset from surface while drawing - one way you can possibly do that now is to drag out a construction line on the surface normal before you place the point. You may need to do a little slight of hand to type in the distance before you finish the construction line to place the end at the distance you want.
I see the idea, and I just try it right now, not very easy :S Probably a solution if I have a unique wire/tube in my model, but I can't imagine placing thousand of wire like that. More over it's also hard to edit the curve afterward (and keeping the offset of course)
>> A kind of "running offset distance" is an interesting idea but may be somewhat difficult to set up, a surface normal has 2 directions on it and it may be difficult for you to predict which is the "positive" side on any given free-standing surface. So just setting a single value and then doing single pick, pick, pick after that probably would not do it properly, you would need to do something like 2 picks with the second pick indicating which side... Might be rather awkward to set up.
Well even 2 click doesnt sounds that bad, I'm quite ease with the MoI navigation so I'm not that affraid by the awkwardness.
Just wondering too, isn't this double normal problem resolved when you works with solids ? It's a bit like the meshing process right, when a geometry is closed you can define where the normal is looking at. (Just a non pragramming lazy guy shorcut :))
EDITED: 3 Dec 2015 by PAQ
2187.17 In reply to 2187.15
Still tunnel vision so the obvious escapes me! duh.
2187.18 In reply to 2187.16
Adding the couple extra profiles made this work.
2187.19 In reply to 2187.12
>> The circle can be positioned quickly by use of Circle / Diameter, followed by rotate widget:
Interessting method, but it requires a couple of more step if the sweep rail is more 'organic' like the rail I build above ... not so easy (impossible) to align the cicle/cross sections with the gizmo method when the rail is turning around something (helix).
2187.20 In reply to 2187.18
Seems a solution indeed (in fact cross sections don't have to be align with the rail, so it's probably a little bit faster than I thought)
I will apply that tomorrow and see how it comes :)
Thanks BurrMan and Michael !
2187.21 In reply to 2187.19
I just did 5 on your model pretty quick! I used to struggle with the "rotation tool". It just didnt work with my brain (granted I never put in the effort to practice and understand it). I wonder, could you use the rotation tool well? The little rotation gizmo has me smiling.
2187.22 In reply to 2187.20
It could be this is that difference in the way people process, which is a profound "MoI" characteristic. I'll bet PAQ is great with the Rotation tool.
Food for michaels thought and a not so obvious example of why MoI will be so successful. Thanks for the lesson PAQ.
2187.23 In reply to 2187.16
Hi PaQ,
Yeah that's true - it just becomes more and more of a pretty specialized thing that only works in particular circumstances.
That's kind of something that would be built directly into the point picker logic itself, mostly I try to have things that go in there be sort of more general purpose use type things and not so much just for one very specific thing.
From some of your later comments, it sounds like putting in an offset circle may work for you better than you thought? You probably don't have to put one in on every spot, just in strategic locations where the path goes through a major shift in direction.
It may be possible to do something with the construction line with a keyboard shortcut to help make that easier. I'll give that a try. I'm not sure if there is enough stuff exposed to script to make that work, I may need to add some stuff to make it work for the next beta.
Is time win to use Array curve for put some circles on the curve then rotate them, and kill some useless?
Then make the sweep
And here it's a particular situation! it's a little rope!
2187.25 In reply to 2187.23
Hi PaQ, the best it looks like I can do for scripting with the current version is something that will set the distance constraint for you with a keypress, so that once you start dragging a construction line you can strike a key and have a distance applied to it, rather than needing to type in in over and over again.
This will do that:
script:var pp = moi.ui.getActivePointPicker(); if ( pp ) pp.setDistanceConstraint( 1.0 );
The way that works, is you start dragging a construction line and have it along the surface normal straight snap, while you still have the mouse button held down, strike that shortcut key to apply the distance constraint, and then release your mouse button to finish the construction line.
Then move your mouse to find the "end" snap on the construction line that will be 1 unit along it from the surface.
You can probably execute that sequence pretty quickly.
You'll probably accumulate a lot of construction lines on the screen with that method. You can also set up another key to erase all construction lines (without exiting your current draw command) by setting up this shortcut:
script:var gd = moi.geometryDatabase; gd.removeObjects( gd.getObjects().getConstructionLines() );
It should be possible for me to add some more things to be available for scripting for the next beta to actually position the offset point all in one shot with a keystroke I think, I will see about adding that stuff in but that won't help until the next beta.
2187.26 In reply to 2187.25
Script language is some fascinating as condensation ideas for create a result in a few time!
2187.27 In reply to 2187.12
Michael,
How did you move the center point of the rotate widget. I'm stuck here. It looks like you drag it but i drag the whole object.
Burr
2187.28 In reply to 2187.27
I'm sorry I got it, Ckick and let go! It's not a drag.
Burr
[EDIT]
WOOOOOOW!
[EDIT]
2187.29 In reply to 2187.28
Hi Burr - yup, click and let go on the rotate grip initially to switch to "wheel mode".
Once you are in wheel mode then that center point stays on and you can go grab it and reposition it.
While in wheel mode dragging on a wheel will do a rotation, and clicking somewhere out off of a wheel exits the mode.
2187.30 In reply to 2187.29
Hi Michael, thanks a lot for the script, quite handy ... but do not waste to much of your time in this.
It's still takes me to much time, whatever the method : the tangant construction line method, or the circle along curve one.
At the end, it takes the same time (or even more) than using the standard method, and editing every control by hand to adjust the rope intersection.
2187.31
Great discussion, guys. I've been using LWCAD v3 to assist with my similar piping needs. That's means I have to depend on getting my models into LW (cleanly) to continue my work...
Anything to assist with these piping tasks within MOI is certain appreciated!
-Will
2187.32 In reply to 2187.31
Well the job Im working is also rendering with lightwave :P ... a bit to late to learn/use/buy for lwcad too :(
I wish a could place 100 of them, but I will not have the time ->
EDITED: 3 Feb 2010 by PAQ
Show messages:  1-12  13-32  33
