Sweep ignoring corners?
All
1-3
4-8
Michael Gibson
25 Nov 2008 (4 of 8)
2183.4
In reply to
2183.1
Hi Duke - currently 1-rail sweep will not do the mitered corners that I think you're looking for there. It is something that I expect to be adding in later on in v2 though.
Check out here for an alternate approach for now:
http://moi3d.com/forum/index.php?webtag=MOI&msg=428.12
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Nick (BODINI)
27 Nov 2008 (5 of 8)
2183.5
In reply to
2183.1
Offset the centerline of your sweep to the inside (so there are 2 lines). Then use those 2 rails for the sweep to get mitered corners.
EDITED: 27 Nov 2008 by BODINI
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
WillBellJr
30 Nov 2008 (6 of 8)
2183.6
Yes this one has urk'd me in the past also!
But as already mentioned, a 2-rail sweep will get you what you originally expected.
I didn't know about the micro bevel getting this to work as well?!
-Will
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
duke
1 Dec 2008 (7 of 8)
2183.7
The 2 rail option seems to be the best. The micro fillet forces the sweep to turn a corner, but it's not a clean result - it goes through itself.
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
BurrMan
1 Dec 2008 (8 of 8)
2183.8
In reply to
2183.7
Also not mitered as I think that was the intended result.
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Reply to All
All
1-3
4-8
