Skp export setting request
2180.1
Just started testing V2. I like it already...
The SketchUp export is great, but could you make the default settings limit the smallest triangle size so that all faces will be created.
SketchUp won't create a face if the triangle is too small, but I don't know how big it needs to be. Here is a small image showing the problem, and as you can se the same shape when exported at a biger size from MoI will not have the holes that were present in the original export.
Sheik
Size: 176.8 KB, Downloaded: 76 times, Dimensions: 816x513px
2180.2 In reply to 2180.1
Hi Sheik, thanks for testing the SKP export!
Can you please post the .3dm model file for that object, or e-mail it to me at moi@moi3d.com ?
That would help me to test and see what I might be able to do.
I don't think that it will actually be possible for me to avoid small triangles in every single possible situation - like for example what if you draw a small rectangle surface that is of that size just all on its own?
It seems like it is a limitation of SketchUp that it is not set up to handle smaller sized details I guess.
But yes I may be able to set a default "avoid smaller than" size for SKP export that could help when exporting curved surfaces like you show there.
If I can get the .3dm file that you show that will give me a reliable test case that I can work with.
2180.3 In reply to 2180.2
Sent to your e-mail...
