Box vs Rectangle
All  1-2  3-7
2171.3 In reply to 2171.2
Easy fix, thanks Michael.
2171.4 In reply to 2171.2
Would this fix only apply to the latest Beta or could it also be used to fix that same bug in V1, as Danny has mentioned?
Just wanting to clarify this, Thanks.
regards Colin
2171.5 In reply to 2171.4
Hi Colin - that previous fix should only be applied to the v2.0 betas since there are some other changes in there for v2 to support feet & inches style units display in numeric fields. V1 won't understand the new field controls in there.
I've attached here a version that can be used to update v1 - unzip the attached BoxCenter_fix_v1.zip file and copy the BoxCenter.htm file over top of the old version in C:\Program Files\MoI 1.0\commands to update v1.
2171.6 In reply to 2171.5
Michael,
Your beta releases are done so well I unloaded V1 along time ago. It cant do what the beta does even if I find a new bug.
Only if you dont release a new beta before this one expires... Then I'll be stuck trying to find v1! Darn it!
2171.7 In reply to 2171.5
"that previous fix should only be applied to the v2.0 betas since there are some other changes in there for v2 to support feet & inches style units display in numeric fields. V1 won't understand the new field controls in there."
I'd figured as much, but just wanted to be doubly sure...especially if someone else was to think that they could fix their V1 using it...
Thanks for that V1 fix too.
regards Colin
Show messages: All  1-2  3-7
