Tangent snap question
All  1-5  6-9
2165.6 In reply to 2165.5
@ PaQ :C'est bien ce que je pensais mon schéma n'était pas assez clair :D
M'enfin je vois qu'on est deux :D
EDITED: 20 Nov 2008 by PILOU
2165.7 In reply to 2165.1
Hi mushroomgod - did this get solved for you now from the replies above?
Yeah - you'll need to use straight snap, which by itself handles the first tangent, then for the ending one as described above you'll need to set up a construction line (by holding down and dragging, also with straight snap still enabled) to set up a kind of snapping guide for placing the second-to-last point.
Let me know if this still isn't clear.
2165.8 In reply to 2165.6
@Pilou Entre mon anglais pourri et tes graphs de physicien je pense que le gars est entre de bonnes mains :P
2165.9 In reply to 2165.8
Between my physicist's graph and the PaQ abstract's drawing, Mushroomgod you will be lucky if you will find your solution! :)
In any case Helpers lines are always your friends!
Show messages: All  1-5  6-9
