New German forum + beta translation
All  1  2-7
216.2 In reply to 216.1
What is a beta translation?
Translation of the documentation or translation of the UI?
216.3 In reply to 216.2
Both!
216.4 In reply to 216.3
What is the process for translate the UI?
In french for example :)
Does exist a ressource "Text file" ? Or some Text's Buttons are also "image"?
216.5 In reply to 216.4
Right now you go through the .htm files that are in the \ui subdirectory (under the MoI install directory in \Program files) and change the text in them. But this is kind of fragile since it is hard to keep the edits there up to date when I make changes to the UI.
I'm planning on making a different string table text file mechanism that will make it easier to just edit just the strings separately and not worry about the structure of the UI so much. So this process will get easier once that thing is finished, which I'm not sure exactly when that will be yet.
Nope, all text is editable text in HTML files.
216.6 In reply to 216.5
< Nope, all text is editable text in HTML files
Cool :)
216.7 In reply to 216.1
Thanks Tony! for translate this
i have registred me today.
CU
Show messages: All  1  2-7
