Scene managment....?...
 1-9  10-29  30-49  50-69  70-89  …  130-135
2150.30 In reply to 2150.20
Thanks for all the replies, Michael.
It sounds really good ... I look forward (as always) to the next beta.
cheers
eric
2150.31 In reply to 2150.30
The next beta will be launch next week ( I wish :) )
2150.32 In reply to 2150.31
Like, say, 9am, 17 Nov, Ausie Adelaide Time!
Brian
(9.30 is ok!)
I got a method set up for editing the size now...
You can put in expressions like 22/5 in there, and also use a + or - sign at the start to make a relative change in size.
2150.34 In reply to 2150.33
COOL, thank you sir...
2150.35 In reply to 2150.33
Looks very impressive... :)
How about this :
Message 2150.36 deleted 16 Nov 2008 by YANNADA
2150.37 In reply to 2150.35
Hi Michael...
Take a look at this video just for your inspirations...
2150.38 In reply to 2150.37
this last one video is more for "polygon" box modeler ;)
2150.39 In reply to 2150.33
since you can enter +2.5 on Z (whence you had 5); would it be possible to incorporate on any given dimension f(d); where f is a function (+, -, *, /) and d is the dimensional value of X, Y, or, Z? This would allow to generate some geometries with proportions; for instance X could be 2*Z. The difficulty for at least a novice user would be to avoid creating a circular relationship.
Cheers,
- Diego -
2150.40 In reply to 2150.38
Is called Instant3D in Solidworks, It’s an answer to Spaceclaim, CoCreate, Synchronous Technology in Solid Edge and NX, etc. "SketchUp on Steroids" as Deelip Menezes said.
Synchronous Technology is very cool tech which Siemens built on top of the Parasolid. (SolidWorks also is based on Parasolid Kernel) http://www.plm.automation.siemens.com/en_us/campaigns/breakthrough/
http://www.evanyares.com/the-cad-industry/2008/5/21/synchronous-technology-and-design-freedom.html
http://www.synchronoustechnology.net/blog/54/editing-imported-models-the-easy-way/ COOOOOOOOOOL
EDITED: 16 Nov 2008 by YANNADA
2150.41 In reply to 2150.35
Hi Anis -
> How to change 3D model directly from 5 to 7mm
This new system will also allow you edit the size of a sub-object like an edge or a face, like this:
I'll probably also be tweaking that a bit, to show length for a line and radius for a circle, rather than x,y,z bounding information for those particular kinds of objects.
But this new system is for setting the size of the entire object, it will not do "constraint" based type operations that may extend and alter interior regions of a shape differently than the shape as a whole.
That kind of interior part modifying requires a lot different kind of mechanism behind it which I don't expect to have incorporated into MoI anytime soon. For that you should use one of those "direct manipulation" style modeling systems instead, like SpaceClaim, Siemens NX, Kubotek, etc... Or it also sounds like there is some new stuff available in SolidWorks for that as well? At any rate, if you need to do those kinds of operations those other modeling systems will be the proper tool for that kind of a job, not MoI.
Just keep in mind that MoI is not particularly focused on being a complete replacement for one of those kinds of modeling systems. If the things you need to do are solved very well already by one of those other systems, then I generally expect that you should use them for that task and not MoI.
EDITED: 16 Nov 2008 by MICHAEL GIBSON
2150.42 In reply to 2150.39
Hi Diego,
It sounds like you may be talking about setting up some kind of persistent constraint that is enforced through subsequent operations?
That kind of persistent relationship would be quite difficult for me to set up right now.
This tool is a kind of "one shot" scaling mechanism, it does not set up a persistent constraint on an object, just does a direct edit of it.
However, it may be pretty easy for me to make a sub-set of what you are talking about (or maybe this even will directly fit what you want?), which would be to have "x", "y", and "z" variables available to the expression that you type in so that you could enter an expression like: 2 * x for the Y: value. That would edit the shape to have that proportion right then, but not set a persistent relationship. There should not be a problem with cycles since the expression is discarded and replaced by the evaluated numeric result as soon as you push enter.
I'll take a look at that.
2150.43 In reply to 2150.41
YeeeHaaawwww! An old friend has come to MoI.
Just to be sure, where you answered:
It WONT do a single edge? Are points included? Position is next :) !
MoI is SO gui it sticks all over you!
2150.44 In reply to 2150.43
Hi Burr,
Sort of... You can set the length of a particular edge, but it sizes the whole object to get that edge to the size you asked for.
Not currently but I think I can make that work.
2150.45
Well, Michael, I take my eye off the forum for a little while and what do I find? Editable size and viewable directly at the top of the interface!!
Great stuff - just what I was hoping for. Hats off to you, sir!
Tony
2150.46
I believe we're on the same page. Though persistent relationships would be great (like that afforded by a constraint middle-ware engine like D-Cubed); that's not what I was asking about or hoping for now.
Indeed at this point the suggestion, or if you will request, is that whatever object you're editing it would be possible to establish a relationship, albeit temporarily, using the very same variables that originally allowed defining that object. For instance, in the box example you'd be able to make the length equal twice the height (x=2*Z). Or similarly for a cylinder, relating radius or diameter and height.
Cheers,
- Diego -
2150.47 In reply to 2150.46
Hi Diego, I was able to set that up pretty easily:
There are "x", "y", and "z" variables that you can use in an expression.
So for example there I entered "y" in for the X: value, to make x and y values equal to "squarify" the box (make sure to turn "Maintain proportions" off if you want to change dimensions independently instead of doing a uniform scale), and then "x/2" for the Z: value to make the height 1/2 of that starting y extent value.
But it is not quite the full package that you were asking for - this just handles the bounding box around an object, regardless of how it was constructed. So something like a cylinder is not treated any differently than a box.
I will be doing some custom editors for certain entities, but probably those will start out just with a line segment length and a circle radius. But actually since a cylinder has edge sub-objects which are lines and circles, just the line and circle editor should actually work pretty well for editing a cylinder as well.
Being able to edit any combination of the original values that an object was created with is going to be something that goes into a "history" editor which will be a different thing than this size editor thing.
Thanks for the feedback, that was a good idea!
2150.48 In reply to 2150.47
Useful :)
And this feature ? (just new in the 7.0 G Sketchup)
Dynamic component
http://au.youtube.com/watch?v=4aVW5X-tb8s&feature=PlayList&p=B62D27FCCF0C34C7&index=2
EDITED: 16 Nov 2008 by PILOU
Show messages:  1-9  10-29  30-49  50-69  70-89  90-109  …  130-135
