Scene managment....?...  1-20  21-40  41-60  …  121-135
2150.1
HI Michael,
not to be annoying, bringing up the ever recurring theme...
but will the first beta with scene management be released soon?
I would really like to be using moi more often....
2150.2 In reply to 2150.1
Hi okapi, it won't be ready by today.... But I am right now in the process of working on the style mechanism for assigning object properties.
It will probably take me a couple of more days to even finish up just the first pass on this, there will still be a lot of work to finish up on object management stuff in the next beta after this one as well.
I'm not entirely sure when each piece will be finished, I want to do this pretty carefully so that the way that I set it up now will be a good way for next many versions to come.
That tends to make things progress somewhat slowly, but I think should give good results when it is finished.
2150.3 In reply to 2150.2
I thought you where just going to put out a new beta to address the reported bugs,.. then chill out a bit,.. then work more on the object properties. (I think the "chill out a bit" is needed most).
Take care,
- Steve
2150.4 In reply to 2150.3
Hi Steve, well that was one idea...
But I've been hoping though that I will be able to get at least a part of the properties stuff done for this release, so I keep on waiting for just a bit more to see if I can get it working better, etc...
I do actually have quite a bit of the underlying stuff working, like you can assign object names, the type and size display works, and properties can be assigned to sub-objects and persist through operations such as booleans.
It is the visual style property part that is still not finished yet that is holding things up.
Some of the ideas that I had earlier I don't think will hold up quite so well when additional types of properties are added later on. So I've been a little bit back to the drawing board a couple of times. But I think I'm on a pretty good track at the moment, actually kind of using the styles and formatting mechanism in Microsoft Word as a model.
I think I may know by the end of today whether the current track is going to work or not.
Some pretty good progress on object properties today.
This shows the size readout changing when sizing an object, and the current concept for editing visual properties (the style editing part is just an empty UI right now, that part is not hooked up yet).
The general idea is that a "Style" will set bundle of visual properties all in one shot.
You can also edit properties individually by going to the other tabs below Styles. Currently there will just be Colors there but in the future more stuff can get added there such as "Lines", or "Textures".
I'm thinking that there will be 2 options for how the styles get created - you can go to a "Style editor" dialog by pressing that "Edit styles" button to change styles or create a new one, but I would also like to make a new style available anytime you go in and set some individual properties directly (like going to the color tab). So for instance if you go in and set a custom color, then after that an entry for that will show up in Styles to make it easy to pick that same color for other objects. It should be a quick way to make a style without actually needing to go to the full editor... That's the current idea anyway.
Still needs some work though!
2150.6 In reply to 2150.5
No unity (cm, mmm...) somewhere?
Colors can be chosen ? (define)
What meaning "CRV"?
2150.7 In reply to 2150.6
Actually I do have those now - I just had my units set to "No unit system".
If you have units set, a small label will appear at the end of the Size: control:
Also units labels will show up in the bottom toolbar after the x,y,z point and distance controls:
And also after distance/length type input fields in command options, like here is one for drawing a circle:
I'm not sure... I probably won't be able to do any kind of GUI editor for them but maybe read them in from a text file that you could customize if you want.
> What meaning "CRV"?
It's short for "Curve". There is not much space in that area, so I have needed to use some contractions there.
2150.8 In reply to 2150.5
Looking good so far Michael! :)
Will there be an inherit properties sort of thing, so we can copy set properties from one object and copy to another ?
2150.9
thanks for the update michael.
Good to see how things are progressing.
What interests me most, more than object properties, is the scene tree.
Being able to assign objects to certain group/layers/parents etc....
to organize complex scenes
and, very importantly, how these groups export as OBJ.
(to be able to import this hierarchy in other programs), as well being able to somehow preserve layer information from Rhino files.
This to me is the single most important thing that is needed to integrate Moi in a modelling workflow.
2150.10 In reply to 2150.8
How about editing the size of a sketch, solid and surface body ?
-anis
< but maybe read them in from a text file that you could customize if you want.
Maybe yes because for graphic aspect those above are maybe clashing with the all screen of the UI ;)
2150.12
Michael,
My 2 cents.
It is very important for me that MoI be compatible with Rhino layers ... interchangeable in both directions.
Otherwise it is very difficult to integrate MoI into my workflow ... except using it for smaller details for inserting into the main work.
Is this part of the overall plan?
thanks
eric
2150.13 In reply to 2150.12
I agree with Eric.
It has to play well with Rhino's layers.
It also has to be able to export hierarchies well, to open in external apps (modo, C4d etc....)
2150.14 In reply to 2150.13
Will the size be "editable" from that properties page?
Opacity/Transparency anywhere in the future?
What about Naomi?
Burr
2150.15 In reply to 2150.14
Hi Michael
Just some questions too :)
1)
About the size info, isn't the lower tab from the MoI interface a better area to show this kind of stuff ? somewhere close to this
For me the upper right place is a really important place in MoI, where every tools options are showed, and I think the size info is not something really 'primary'.
I don't said it's not an important info, but maybe I will more look in the bottom for this numeric info, like the world position etc.
2)
Will style include shade mode (wireframe, solid, solid + wireframe etc), transparency, specular etc etc ? ... I mean is it some kind of surface editor that also include dx shader like for example world image reflection, toon shader, etc. Would be great if it might be compatible with stuff comming from shaderfx kind of software ->
http://www.lumonix.net/shaderfx.html.
A thumbnail system that will show the style look would be sexy too (if I really understand what styles are)
3)
Like few others, I can't wait to see any kind of system that will help to manage bigger scene ( layers =o) ? )
EDITED: 3 Feb 2010 by PAQ
2150.16 In reply to 2150.8
Hi Danny,
The current idea is that once you set properties on one object, a new style will then be available after that in the Styles section.
So if you want to apply the same properties to another object, select the other object, and then apply that new style to it.
I'll probably see how that works first, but I'm also thinking of adding a "Match" button to that flyout in the lower-left corner, which if you pushed it would let you pick an object and suck its properties over to the ones that you had selected before that.
2150.17 In reply to 2150.9
Hi Okapi,
This will be coming in another beta release beyond the next one.
My first area of focus is this properties panel stuff, and once that is wrapped up then I will be moving to that object browser / scene tree type thing.
It will probably take a few beta releases before it is all wrapped up and fully working.
2150.18 In reply to 2150.10
Hi Anis,
Actually you can do that currently with the Transform / Scale command.
But I am planning on some alternate ways to do it, I had been thinking of doing the editing on a "Details" dialog (which won't be ready for this next beta), but maybe I should revisit editing the size in that new Size readout as well.
2150.19 In reply to 2150.11
Those ones are just some quick test items, they are not the ones that will be in there when it is finished up.
2150.20 In reply to 2150.12
Hi Eric,
Yes - I do want to have data transfer including layers.
They may not quite completely map since I'm not doing an implementation of "straight layers" within MoI, to try and avoid some of the limitations that system has.
I think you'll probably be able to choose whether you want to export MoI Groups as layers, or whether you want to export MoI Styles as layers. And maybe the default should be Styles since that will be a singular property of an object similar to how an object can only be on one layer in Rhino.
This interchange with layers will not be part of the first beta with this stuff in it though, my initial focus is on getting a good UI and workflow set within MoI and once that is looking good I will be looking at data interchange after that.
Show messages:  1-20  21-40  41-60  61-80  …  121-135
