If i want to see the left side , what should i do?
 1-5  6-25  26-31
215.26 In reply to 215.24
> it seems not to be noticeable, it just reloads some functions/methods
> each 1000miliseconds, though
It should be fine. But since there is no seconds readout, I think the only reason why you've got it checking once a second is so that it can appear or disappear fairly promptly when window is switched between fullscreen or not?
There is a different way to do this called "binding", which you can use to trigger something when a variable inside of MoI changes. By using binding to control the visibility of the clock, the clock update interval can then be changed to only once a minute (as in the attached version).
215.27 In reply to 215.26
You are absolutely right, Michael. Thank you for your improvement!
I just wanted to show how MoI is fully customizable, nothing else...
Petr
215.28 In reply to 215.27
Well, this is actually a pretty cool customization. Someone has previously requested this exact thing.
If you can just implement a few more user requests, maybe I can take a vacation or something! ;)
Let me know if you have any questions about doing any other customizations.
215.29 In reply to 215.28
Cool functions seems better and useful than an outrageous possibilities of customization :D
215.30 In reply to 215.28
When we were discussing world/plane coordinates input recently, you mentioned that there isn't a "concept of active view" in MoI currently. However, I have been going through discussion forum and I have discovered 'getViewportUnderMouse()' method. Considering tablet users and their way of working without mouse, I guess this is somewhat like special-purpose method, not widely used one.
Petr
215.31 In reply to 215.30
Well, that method works with a tablet as well, since the tablet also functions as a mouse. I guess I should have called it getViewportUnderCursor() to be more exact.
That was added in to make it possible to make a keyboard shortcut that would maximize the viewport the cursor was over when pushing the space bar.
Internally there isn't really anything that is particularly controlled by the viewport under the mouse. A few things pay attention to it for some smaller details, like redrawing that viewport first.
Show messages:  1-5  6-25  26-31
