Smooth transition
 1-8  9-28  29-48  49-68
Message 2140.9 deleted 7 Nov 2008 by MER
2140.10 In reply to 2140.8
Hi PaQ....
Your tips not tangen but looks good enough....
Below is the zebra strips :
EDITED: 19 Jun 2010 by ANIS
Just a question : why the object of the first post can't be "explode"? (separate)
I want just keep center curves lines an no need of the half cylinders surfaces for have only crossing structure
The only solution i had found is copy move lines needed!
2140.12
Any suggestions Michael?
2140.13 In reply to 2140.11
The 3dm file Danny originally posted has many duplicate items in it. try to delete all the extras first to have only one of each.
2140.14
Thanks Anis for the zebra, yes I can imagine continuity trouble with the network surface.
Here's an other way
But I get some trouble with the g1-g2 blend, getting really strange result , I will post it a little bit later.
EDITED: 3 Dec 2015 by PAQ
2140.15 In reply to 2140.1
Hi Danny,
> and what other tools from other (NURBS) apps out there would do this easily?
Really the easiest way to get a very evenly smooth branching structure tends to be using subdivision surfaces. Tsplines is probably the best for that since it will allow you to generate NURBS output.
An example here:
http://www.tsplines.com/community/casestudies/jewelrydesign.html
However, by using that method you also will sacrifice a bit of accuracy because the straight "tube" parts will be part of the melted-down type surface and will not be an exact perfect cylinder shape like you've got in your actual model here.
But if you are focused more on the blended area than the straight parts, then that is probably the easiest way to get very natural "all directional" blending.
Other than that with traditional NURBS tools you probably need to use an "n-sided patch" type tool that will place a fitted surface that is tangent to the input edges (MoI does not have this tool yet).
But it is best to narrow down the area that will be patched to a small region instead of a large region. I would do that using the method that PaQ showed above by doing some blends between the pieces where possible to reduce the area to be patched, like this:
It tends to be harder for that kind of "N-sided patch" tool to do its job if the edges are bending around a lot, often times that tool works by starting with a best-fit plane and then deforming it along the plane normal to fit the shape. The more than you can reduce the area to be fit to be semi-roughly planar will help with that.
Currently in MoI I think that PaQ's method is the best. And actually the zebra results show a pretty good tangent result there.
EDITED: 7 Nov 2008 by MICHAEL GIBSON
2140.16 In reply to 2140.10
Hi Anis,
Actually it looks pretty much tangent to me from those zebra stripes that you showed there.
You may be confusing tangent continuous with curvature continuous.
When the zebra stripes are aligned with one another but have a kink where they meet, that is tangency. You can see the same thing happen on rolling-ball fillets as well. It is when the zebra strips do not even line up with one another that you don't have tangency.
If you want to have stripes not only aligned but also at a smooth transition - that is curvature continuous which is another level of smoothness beyond tangency.
The main thing with that method is that the filled-in patch is actually a planar surface with no curvature to it, so that part is only going to be tangent to the surrounding blends, not curvature continuous.
Can you please post the model of the result you got in SolidWorks? Since it is one surface it is certainly curvature continuous on the interior of itself, but often those tools only produce tangency where they meet with the adjacent surfaces.
2140.17 In reply to 2140.11
You can explode/separate objects that are made up of multiple pieces.
The surfaces in that original post are all just single-surface objects, they don't have multiple surfaces in them to explode out.
Same thing with the curves - those curves are made up of a single segment. Separate can be used to explode a multi-segment curve into individual segments, but when used on a single segment curve it will not have any effect.
I noticed that the original model does have several duplicate pieces stacked up on top of each other, 2 copies duplicated in one spot and 3 copies in some other spots. Is that possibly causing some confusion?
2140.18 In reply to 2140.15
Hi Michael, PaQ
Yes I agree, that was the final method I came up with as well, PaQ you can use 'Planar' surface also to patch that last bit it is actually flat.
I Like the way you ended that sentence with 'yet' what other 'yet' tools are you thinking Michael ? :)
Hi Burr,
Doh! thanks for the pickup Burr, It looks like I left the circular array item count at the default of 8......Corrected!
Thanks to all
2140.19 In reply to 2140.12
The way PaQ posted here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=2140.8
is what I would suggest...
It does end up with a planar piece in the top part which does not seem to be an unreasonable result.
If you don't want to have a flat piece at the top there, then it will be a lot more difficult, you'll probably need to use a different program that has an N-sided patch tool in it for that case.
If you really want to emphasize very evenly smooth junctures above all else, then possibly t-splines would be best.
2140.20 In reply to 2140.17
I have seen that and kill some of them ;)
But that was "the one surface" of half cylinder who pertub me :) (false reflex of the polys of sktechup :)
As Copy / Move lines selected is permitted no problem to use the lines :)
2140.21 In reply to 2140.18
Hi Danny,
:) A lot of stuff!
Eventually I would think I should get the full set of kind of "traditional" NURBS tools in here...
Some tools tend to be rather finicky and take a while to get working well, N-sided patch happens to be one like that.
But current priorities are a lot more oriented towards the "simple stuff" still. Like I currently have a higher priority on making a better and deeper history function for making basic edits work better, rather than putting a priority on "fancy" / advanced surfacing tools.
2140.22 In reply to 2140.21
That's ok Michael as long as those things are in the pipeline, and we know how long the Transcontinental Pipeline is ;) but we can wait as MoI is already a productive piece.
2140.23
Yeah, Paq's method works like'a charm. I even did a shell and it's perfect.
2140.24 In reply to 2140.7
Hi Anis,
>I dont know how to create those shape in moi
Thanks for the demo, is it possible to post an iges, step or .3dm of the Solidworks result so we could have a closer look ?
2140.25 In reply to 2140.24
HI Michael, Danny...
Here is what you want.... :)
2140.26 In reply to 2140.25
Hi Anis,
If you examine your SolidWorks result with Zebra stripes across the whole model (instead of only on that one single patch itself), you can see the same kind of zebra line breaks in it, just in a different location where the patch touches the straight parts.
Again though - that does not mean that it is totally discontinuous there - because the zebra stripes line up it means there is tangent continuity there.
2140.27 In reply to 2140.26
If you examine that same area with the MoI generated model using PaQ's method, it looks like this:
That same area is very nice with this method.
But instead you get the tangent-only area in a different location - where the top plane touches the blends.
I would think the best compromise shape would probably be to do those side blends but only about 3/4 of the way towards the top instead of all the way to the top. Then fill in the remaining area with an N-sided patch or "fill" instead of trying to fill such a larger area with it.
2140.28 In reply to 2140.26
Hi Michael....
Yeah, thanks for checked it....
BTW after object organization done, have you a plan to add some surface or modeling tool for V2 ?
-anis
Show messages:  1-8  9-28  29-48  49-68
