Thread Screw Problem
All  1-9  10-12
2133.10 In reply to 2133.9
Hi Brian, no problem! Yes, since that cut out piece is totally on the interior it is a bit hard to see.
2133.11 In reply to 2133.10
Michael/Petr
"The main thing is if you want to use the Twist:Flat option for sweep, you've got to get your path oriented along the world Z axis direction."(Michaels earlier post)
Is this documented anywhere?
Should it be in hidden secrets or something?
Brian
ps OK I found it on page 45 of the Help. However, for me, I think the help is a little ambiguous maybe and Michaels sentence above may be better.
But remembering is another matter.
Could the Flat (on the options list) have a little Z and up pointing arrow alongside it perhaps?
Brian
EDITED: 4 Nov 2008 by BWTR
2133.12 In reply to 2133.11
Rather than doing that, I think when I have a chance to work on it I will be switching things around so that you will have some different options for which direction is considered the "flat" direction instead of it being fixed to world Z.
Maybe I will also be able to have an "auto" direction mode that will align the direction automatically for helix curves.
Show messages: All  1-9  10-12
