Display units like m,cm and mm
All  1  2-3
2131.2 In reply to 2131.1
Hi J.O. -
I think that you've got a couple of different requests in here.
One part is about the grid changing dynamically and having its size show in the viewport corner, is that correct?
Usually I find that the grid dynamically changing size at different zoom level tends to really impair my own ability to judge the size of things, because normally I do that by looking at the object in relation to the grid.
I suppose that is why they added that readout in the corner in Modo, to try and counteract some of that disorientation.
But when the grid stays fixed at a known size, then there is no disorientation to have to try and counteract...
I can see adding this in as an optional thing that could be enabled, but that will probably be a while before I can get to that one.
But then I think you've got another thing requested there which is some labels for the current unit system, like cm, mm, m after a numeric input field.
That part I think should be feasible to add in much sooner, I will take a look at doing that one soon.
Additionally you may be interested in the recent discussion about possibly having a readout that displays the selected object's size here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=2127.43
2131.3 In reply to 2131.2
Hi Michael.
Depending on the size of the object and where the "camera" is placed, the dynamic grid can be confusing. I don“t need that, but the labels would be nice. :)
Thanks!
Show messages: All  1  2-3
