How can i make the intersect line..?
All  1-2  3-4
213.3 In reply to 213.1
Yes, right now as Pilou mentions you have to use Trim or perhaps a Boolean to get the curve.
In this case, do boolean union or trim, the select the intersection curve, do Edit/Copy, Undo the boolean, then do Paste. This will leave the intersection curve.
There currently isn't an intersect command like in Rhino. I do want to add one, but I haven't quite found the right place in the UI to put it. I think that I may end up with a new section under Construct/Curve, that will have some curve-from-object generation commands, including contour, curve projection, and then probably intersect would go there as well. But this will be several betas away before it happens.
213.4 In reply to 213.3
thanks..Michael Gibson
Good..
Show messages: All  1-2  3-4
