obj output
All  1-12  13-14
2123.13 In reply to 2123.12
Hi Steve, ok I think I see what you mean. You're using a different set of shortcuts than what I wrote above, like you're using something like "2 = Nudge Down", rather than "DownArrow = Nudge Down", is that correct?
In v1 you could use number keys for shortcuts but it can cause some problems because sometimes it would execute your shortcut and other times if there was a command running with a text entry control in it (like the radius of a circle for example), it would put focus there instead of executing your shortcut.
Rather than have this kind of inconsistent treatment, for v2 I've switched this so that the number keys are more reserved for numeric value entry instead of being shortcut keys.
2123.14 In reply to 2123.13
>You're using a different set of shortcuts than what I wrote above, like you're using something like "2 = Nudge Down", rather >than "DownArrow = Nudge Down", is that correct?
Yes. But I have now changed them and all now working correctly.
Regards,
- Steve
Show messages: All  1-12  13-14
