The end curves are the construction lines, there is no need to create curves between them.
So first you will have:-
On the right is a circle split into 6 sections, on the left, 6 circles trimmed with each other.
You then select the curves and extrude them
you then need to delete or hide the curves so you can select the edges of the extruded surfaces:
Then blend those surface edges.
Once all done, You can then delete the extrude surfaces as they are not needed.
