Creating freeform curve with coordinate list
All  1  2-4
2116.2
I agree it would be a nice feature to be able to import (and export) point data. Useful for us CNC machine people, with some post processing of the data.
If MoI does not plan to have this feature you might try Corel Draw. I have generated 2D drawings from data in an Excel spreadsheet. A simple macro in Excel's Visual Basic converts the 2D points to HPGL plotter language ( .plt format) which Corel Draw can import. Then export your drawing to MoI.
Ed
2116.3 In reply to 2116.1
Hi Jukka-Pekka,
> Is it possible to create a freeform curve (through points) by
> using xyz-list from text file?
This is possible using a plug-in custom command that Petr wrote, which you can get here:
http://kyticka.webzdarma.cz/3d/moi/#ImportPointFile
That has an option to create either point objects, a polyline, or a a freeform curve with the points loaded in from the file.
2116.4
I will try that one. This kind of feature will make life a whole lot easier. Thank You Michael & Ed!
- Jukka-Pekka Vikholm
Show messages: All  1  2-4
