Miscellaneous models
 1  2-21  22-23
2113.2 In reply to 2113.1
Thingy #2
Size: 47 KB, Downloaded: 29 times, Dimensions: 816x650px
Size: 54 KB, Downloaded: 44 times, Dimensions: 816x650px
2113.3 In reply to 2113.2
Thingy #3
Size: 79.6 KB, Downloaded: 39 times, Dimensions: 685x746px
Size: 66.2 KB, Downloaded: 64 times, Dimensions: 685x746px
2113.4 In reply to 2113.3
Thingy #4
Size: 88.3 KB, Downloaded: 29 times, Dimensions: 1002x688px
Size: 101.8 KB, Downloaded: 54 times, Dimensions: 1002x688px
2113.5 In reply to 2113.4
#5
Size: 63.1 KB, Downloaded: 21 times, Dimensions: 887x679px
Size: 80.2 KB, Downloaded: 44 times, Dimensions: 887x679px
2113.6 In reply to 2113.5
Rust
The Thingy#3 looks much like the top of my oxygen bottle!
Nice clean modelling---don't think the lack of reply indicates a lack of interest in your work.
It's great to see people progressing.
Brian
2113.7 In reply to 2113.6
Thank you Brian. I´ve been lurking around this forum since day one, and it´s about time I start learning this program and post some work.
I´m modeling some first-aid equipment and it´s easier to get them into Autocad. using Nurbs instead of Poly/modo. They don´t have to be perfect. :)
#6 - Not accurat at all, but kind of a "look-alike" ;)
Size: 92.7 KB, Downloaded: 38 times, Dimensions: 936x701px
Size: 131.3 KB, Downloaded: 65 times, Dimensions: 936x701px
2113.8 In reply to 2113.7
#7
Size: 82.2 KB, Downloaded: 10 times, Dimensions: 1079x662px
Size: 86.4 KB, Downloaded: 12 times, Dimensions: 1079x662px
Size: 98.8 KB, Downloaded: 14 times, Dimensions: 1079x662px
Size: 96.5 KB, Downloaded: 9 times, Dimensions: 1079x662px
2113.9 In reply to 2113.8
#8
Size: 66.8 KB, Downloaded: 12 times, Dimensions: 829x654px
Size: 85.8 KB, Downloaded: 30 times, Dimensions: 829x654px
These are all turning out quite well, it is cool to see them!
2113.11 In reply to 2113.10
Thanks Michael. :)
2113.12 In reply to 2113.11
A super quick and "plain" laptop...
2113.13 In reply to 2113.12
#10
2113.14 In reply to 2113.13
I like this - can you share your technique for making the nuts? Would be much appreciated.
Tony
2113.15 In reply to 2113.14
Hi Tony. I guess there´s many ways of model nuts. I recorded a video showing two ways.
My first Screencast.com upload, so I hope it works. Use this link > http://www.screencast.com/t/551hQLI22E
2113.16 In reply to 2113.15
Works fine but you have forgotten forget to say "Press Details" for dowload the video ;)
2113.17 In reply to 2113.15
Hi J.O. - cool video!
It seems that Screencast.com is not set up to embed QuickTime (.mov) videos into other web pages.
I think if you use Flash format (.swf) or possibly .wmv (not sure about .wmv though), it will give you a little bit of HTML code that you can paste into a web page or also into a forum post here to have the video player show up directly inside your post (http://moi3d.com/forum/index.php?webtag=MOI&msg=2042.25).
Not a big deal, but possibly the embed method is slightly easier for viewers.
2113.18 In reply to 2113.17
Thanks guys.
I have some problem with the Jing app, and I usually use QT (iShowU) and my .Mac site to post my videos.
The .swf files get rather big I think?
Will try some more :)
2113.19 In reply to 2113.18
Hi J.O.
Yeah, they tend to be somewhat larger, but also somewhat more "web page oriented".
To cut down on download size what I do is actually record at full normal application size but then produce the final video scaled down to 640 pixels in width.
Anyway, your current method is fine. I had assumed that you were using Camtasia to do the recording since that is made by the same people that do Screencast.com .
2113.20 In reply to 2113.19
Yes I did use my old Camtasia 3, and manage to get the .swf file size down to 29 mb. The QT H.264 export failed, so I used Mpeg4. The Mpeg4 was around 10MB and the H.264 would be even smaller.
In the future I wil try to put up a download page of MoI videos, like I did for Modo http://homepage.mac.com/janoverust/FileSharing26.html
2113.21 In reply to 2113.15
This is great. Thanks very much. I had no end of trouble making a nut. Ended up with weird multiple curves and all sorts of rubbish. Don't know why I didn't think of using the cone :-)
Thanks again.
Tony
Show messages:  1  2-21  22-23
