Hypershot and MoI's 3dm format
All  1-3  4-7
2112.4 In reply to 2112.3
Hi Paolo and Michael for your answers.
It seems that obj format is the best for rendering with hypershot.
i am only experimenting with this interesting renderer.
Regards,
George
2112.5 In reply to 2112.4
If you render sphere from within Rhino 4, with renderer Hypershot, this come fine. But if you open from Hypershot sphere.3dm, the result is a polyhedron, as described before. Probably a Hypershot bug.
George
PS. Works fine with Hypershot plugin for Rhino, inside Rhino 4.
EDITED: 26 Oct 2008 by GKSL4
2112.6 In reply to 2112.5
Hi George, I see - when you do the rendering directly inside of Rhino it is using Rhino's mesher instead of HyperShot's mesher, so it avoids the problem which seems to be with HyperShot's meshing mechanism.
One other note - if you do export as .obj from MoI (which is probably the overall best way just make sure to use Output:Quads & Triangles to avoid n-gon processing problems), HyperShot will tend to only apply one material for a whole object and not allow you to apply different materials to different sub-parts of an object.
There is a utility you can get from here:
http://moi3d.com/wiki/Resources#SeparateOBJ_editor
which you can run on an .obj file exported from MoI to add some material flags to the file which will then make it work better for assigning different materials to sub-object parts in HyperShot. At some point in v2 this will get added built in to MoI's regular .obj export.
2112.7 In reply to 2112.6
Sorry not watching your previews answer. So I edited my previous message, before reading yours.
Thank you again for the immediate response.
Regards,
George
Show messages: All  1-3  4-7
