Batch file conversion
 1-20  21-40  41-48
Thread Split: Some posts in this thread were moved from here
2100.41 In reply to 2100.40
Hi Michael, it works now. It was the mesh option at my MoIConvert.js script file that override the "persist" allways. Thank you. :)
For the options UI - in the past at Rhino 3 there was a render plugin called Rhinoman. It allow to render per render engines based on the Renderman standard. The Renderman standard allow to use dozen of options and so the coder Brian Perry added a simple list/table UI for seldom needed features. At this simple tables/lists the user could add options like needed - first column option name and second column value. I see now that you implement something like for the shortcut keys.
Why not add a button somewhere at the general options that open a window with a table that show the moi.ini? So, the user don't need to search it at the hard disk, get quick&easy access and you don't need to work on the UI for every little new options. The MoI interface is so nice sophisticated - this little addition could make it perfect for the advanced users too. For me it sounds like a must. ;) The UI wouldn't be complicated, only a little button needs be added. At the general options you could add a line "MoI ini file" with an "Edit" button. An advantage would be, that if the user has more than one ini file at his system (by an user fault), that the UI would only open the ini file that is known and used by MoI.
If you would add the table, than you could make that all options titles like [Mesh Export] could be show bold or with a empty line before.
Visualisation for Designer and Architects - www.simulacrum.de
2100.42 In reply to 2100.41
Hi Micha, re: "Advanced options editor" - yes Firefox has a kind of similar thing, if you type in about:config in the address bar.
It would certainly be useful!
The main problem would be that I would need to divert time to work on it and I would need to cancel other features in order to make that one.
Yeah adding the little button itself would be easy.
Unfortunately making the whole table part which actually would function dynamically is a lot more work than that.
Beyond just making the table UI itself, it would also require an integration layer to make the table hooked up to each of those settings in the actual MoI code.
It's easy in the sense that it is not "rocket science", but it is not unusual for things that are not necessarily difficult to still take a lot of time to implement.
I can understand from your perspective it seems very simple, "Just add a button and a table, how long could that take?" .... If only things really worked that way I would be happy!
It's unfortunately pretty common for many kinds of things to take a lot more development time than you might initially imagine.
This would just be too time consuming of a thing to develop right now.
Yes, this one is a lot more feasible, and I've thought about having a button to launch the current moi.ini file in a text editor.
There is a complication with this too though, because MoI writes settings to the moi.ini file when it shuts down. So it is not so good to have the moi.ini file opened in a text editor while MoI is still actively running since if you edit the text and then save it while MoI is still running, your changes will then get overwritten when MoI shuts down and also writes to the file.
So such an "edit moi.ini button" would need to shut down MoI and wait until all settings have been written and only launch moi.ini in the text editor after that.
That's slightly unusual to have a button in options which will shut down the program like that, which is why I haven't done it yet. I guess I could put up a warning dialog first like "To edit moi.ini, MoI will now shut down. Do you want to proceed?" or something like that, that may work.
EDIT: I think I misunderstood your last part here - you were talking about using that button to show that special "Table UI". The thing I'm talking about here would be to have a button that would launch moi.ini in a text editor like notepad.
2100.43 In reply to 2100.42
Thanks for the detailed answer - I understand. I'm curious how long you can stay an one-man-company. ;)
2100.44 In reply to 2100.43
Hi Micha, yup this is exactly the kind of thing that would be possible to hand off to other programmers to finish for me if I had some other programmers working for me.
Because I don't have that, I have to be pretty careful about working on things that have a combination of relatively time consuming but not high value general overall return.
There can be some hidden (sometimes very well hidden...) benefits to having limited resources though, since it can force greater precision and help to avoid feature bloat.
2100.45
Hello guys,
I'm trying to convert all igs files in a folder into fbx format...
So i've downloaded the last pack i've found, from Michael...
I've changed the BatchConvert.js to start ConvertFolder( 'c:\\test', 'igs' );
and i've changed 'obj' to 'fbx' into Convert.js...
When i start the cmd, i get a script error :
ReferenceError : Can't find variable : Enumerator... line 46...
here are my scripts :
BatchConvert.js :
// This is the script file that you would generate, put one line in
// for each file you want to convert.
#include "Convert.js"
//Convert( 'v:\\Oskab\\convert\\Angle haut 700 x 600.igs' );
//Convert( 'v:\\Oskab\\convert\\Angle haut 924 x 600.igs' );
//Convert( 'v:\\Oskab\\convert\\AR9 P Arr 696 x 376 x 3.igs' );
ConvertFolder( 'v:\\Oskab\\convert', 'igs' );
moi.exit( true ); // Pass true to suppress save changes prompt.
Convert.js :
function Convert( FileName )
var gd = moi.geometryDatabase;
// Open the file, set 2nd param to true to suppress any save changes prompt.
gd.open( FileName, true );
// Create the output file name by breaking off the file extension and adding 'fbx'.
var FBXFileName = FileName.substr( 0, FileName.lastIndexOf('.') + 1 ) + 'fbx';
// Save out to the output file, passing the option to suppress the UI. You
// add other options separated by semi-colons with no spaces. These
// options are available for controlling the meshing:
// (note: | denotes mutually exclusive options, for example for Output choose one
// of the given options, like Output=quads)
// NoUI=true
// Angle=12.0
// Output=ngons | quads | triangles
// MaxLength=0.0
// MaxLengthApplyTo=curved | planes | all
// MinLength=0.0
// AspectRatio=0.0
// Weld=true
// Display=shadedwithedges | shadednoedges | wireframe
// ExpandedDialog=false
gd.saveAs( FBXFileName, 'NoUI=true' );
// Let's clear out and suppress any save changes prompt again.
gd.fileNew( true );
function ConvertFolder( FolderName, FileExtensionToLoad )
// Convert all files within a given folder, that have the given file extension.
// For example, convert all .3dm files inside of the folder c:\test :
// ConvertFolder( 'c:\\test', '3dm' );
// Create the FileSystemObject to get access to files and folders.
var FSO = new ActiveXObject( 'Scripting.FileSystemObject' );
var Files = FSO.GetFolder( FolderName ).Files;
// Go through every file in the folder.
for ( var FilesEnum = new Enumerator(Files); !FilesEnum.atEnd(); FilesEnum.moveNext() )
var File = FilesEnum.item();
var FileName = File.Path;
var FileExtension = FSO.GetExtensionName( FileName );
// If the extension matches the kind we are converting, call Convert() on it.
if ( FileExtensionToLoad.toLowerCase() == FileExtension.toLowerCase() )
Convert( FileName )
Michael?... some help ?... thanks in advance...
Size: 35.6 KB, Downloaded: 38 times, Dimensions: 458x350px
2100.46 In reply to 2100.45
Hi naxos - it looks like that script is using some stuff specific to the Microsoft Jscript implementation which MoI used to use for scripting in MoI v1 and v2.
V3 has switched to use a different script engine and so that one particular area of the script will need to be altered. I'll take a look at that.
But also if you just use MoI v2 instead that same script should work now I think, so that's another solution.
2100.47 In reply to 2100.45
Hi naxos, this will require an update to MoI in order to get this script to work in MoI v3 - the script happened to be using a Microsoft-scripting specific mechanism for going through the files within a directory. I'll need to make a built-in method in MoI to handle that part (and the script will need modification to use the new method) since the new script engine in v3 is not able to interface directly with that previous library that the script was trying to use.
So for the next v3 beta there will be a solution for v3 but for the moment to get this script to work you will need to use MoI v2 instead.
2100.48 In reply to 2100.45
Hi naxos, I've added a new script method for the next v3 beta so that this will be able to work in v3.
With the next beta you'll be able to use this for the ConvertFolder() function inside the Convert.js file:
        var Files = moi.filesystem.getFiles( FolderName, '*.' + FileExtensionToLoad );
        for ( var i = 0; i < Files.length; ++i )
            Convert( Files.item(i) );
But until the next v3 beta is out you'll need to use that version you've already got but with MoI version 2 instead of MoI version 3.
Thanks for reporting the problem so I could get v3 tuned up.
Show messages:  1-20  21-40  41-48
