error sweep in moi
All  1-13  14-18
2090.14 In reply to 2090.13
Hi Anis,
>Are you using this technique ?
For the construction lines yes.
For the G1/G2 blends (last 2 pics above), extrude the top circle to a surface and then blend with the the main body.
EDITED: 3 Aug 2009 by MANZ
2090.15 In reply to 2090.14
Hi Steve...
The problem is that the bottom surface is come from multiple curves ( check my original file on my first post ) :
2090.16 In reply to 2090.15
Hi Anis,
Yes, but your original surfaces/curves are not good for later blending/constructions. Even in Rhino a 2 rail sweep using your curves will not give a clean/smooth surface.
Rhino:- 2 rail sweep:-
The problem is that the curves for the main body are not all connected to at least G1, so it will cause further problems, even possible problems with output for rendering. It is better for such a simple shape to use a circle or oval and then move the control points to create the correct shape as I did on the examples I posted.
2090.17 In reply to 2090.16
Hi Steve...
I am never tried in rhino before, thanks for checked it.
When apply fillet i use "circular" ( see below ), I will try to use G1, G2 & G3 and see the result.
EDITED: 19 Jun 2010 by ANIS
2090.18 In reply to 2090.17
Below is the result use sweep 2 rails :
Show messages: All  1-13  14-18
