Hi Nick,
> Is there a way to do MoveTargetToObjects in MoI?
Yes - use the Reset button at the bottom of a viewport here:
When you push that button, it will move the Target / Pivot point to the center of the selected objects. After that the 3D view rotation will pivot around those objects.
Also you can press it a second time to zoom to fit all objects instead of only the selected ones.
If you want to pivot around a very specific point other than the center point, you can set the pivot point to a particular spot by using the Area button on that same toolbar. It lets you pick a zoom window by the center point and then a rectangle around that, and the center point that you pick will become the pivot point.
